gmen78
Re: [TUT] Installing Android CyanogenMod 7.1 Alpha 2a on HP Touch
k thx, will give this a shotThe novacom program is meant to be launched from the command line (The CMD programme in Windows XP terms).
When you double-click on it it will run but because it has nothing to do (it's actions are specified on the command line) it will immediately exit.
On my XP box I would:
1) Windows Menu --> Run --> Type 'cmd' <enter>
2) In the resulting box I would type 'CD C:\Program Files\Palm, Inc' to enter the directory (my directory is the default, yours may differ)
3) Then run the command as specified in the installation instructions:
novacom boot mem:// < ACMEInstaller
Make sure you have extracted the ACMEInstaller file from the zip and it's in the same directory as novacom.exe, it should have no file extension.
