Results 1 to 6 of 6
    Default how long does the battery last with cm7 alpha 3.5??
    I am eager to install cm7 but not before the battery is have been fully solved.
    and I have heard there is 3.5 is released and this time there is no mention of battery so i wonder if it is been fully resolved or not solved at all this time.
    let me know how long it lasts! thanks.
  2. #2
    leebtyler's Avatar
    Posts
    Global Posts
    23 Global Posts
    Default Re: how long does the battery last with cm7 alpha 3.5??
    cant be specific, but im using 3.5 at the moment, battery life is stated at 9hrs for me, and i know ive gotten at least 6 out of it before i got bored and turned it off, this was intermittent browsing and playing with apps using an app that manages my battery life and usage, hope that helps.
  3. #3
    My battery life is just as good if not better than my experience with webOS on the unit. They took care of the draining issue amongst the first releases.
  4. #4
    my battery life is subpar. after seeing this problem I also tried to throttle cpu on sleep. Altogether it got a little better. However it doesn't come close to what I get in webos. I would say 2/3rds compared to webos.
    reading the xron thread and cm7 thread it seems to be a problem for a number of people. sometimes a reflash works and improves battery life. that did not help for me though.
    hope this gets better in the future
  5. #5
    DemonHighwayman's Avatar
    Posts
    Global Posts
    307 Global Posts
    ROM
    Cyanogenmod 9 RC
    My battery life since alpha 2 is comparable to webos if not better. I think everyone is starting to realise that there are hardware variations with the touchpad. So everyone has been getting a slightly different experience with android on the touchpad.
    The only way to find out how it'll work on your touchpad is to load up cm7 and give it a go. It's not going to do any damage installing it, and if the battery life does suck then you don't need to use it until a newer rom comes along which may sort it for you, after all it boots to webos by default after android is installed.
    So nothing ventured, nothing gained !
  6. #6
    My battery life is not as good on CM7 than it is on webOS. I think 2/3rds life of webOS is a good estimate for me.
