I have been running CM9 nighties for some time now with no issues on my 16GB US WiFi only Touchpad. I installed TWRP and after some time decided to remove it and just use CWM. After trying several things from the posts (which would not work) I decided to remove CM9 completely then reinstall. This is where I got into trouble...
I loaded all necessary CM9 files in the cminstall folder on the Touchpad. I successfully ran ACMEUninstaller and got back to the WebOS language selection (i.e. the initial WebOS screen from factory). Instead of logging into WebOs (felt there was no-need since I never use it), I put the unit in Download mode (vol down + power). I then ran ACMEInstaller2. I received an error (text on the black touchpad screen which I assume is the bootloader) saying the needed files were not installed and something like "remove the wall". I thought I would reboot the unit and now log into WebOS and reinstall the CM9 files (thinking I made a typo when loading them). Now I cannot get the Touchpad to reboot - totally black and even when connected to the PC I dont get the USB connection sound.
Does anyone know if there is a hardware method to bring the unit back (maybe a different sequence of button presses or shorting a pin on the USB connector)? I have tried home+vol up+power, home+vol down + power, home + power, and of course power only and home only. Each combination was held for 30 seconds and then again for a minute and with power connected, PC connected, and nothing connected to the USB port.
Any thoughts would be greatly appreciated.
