1. delta7's Avatar
    I just got a 10, nice phone but terrible battery life how do I fix the battery life issue?
    03-31-2017 11:56 PM
  2. Tim1954's Avatar
    Those numbers don't look to bad.
    If you have used 4% since you unplugged it, the numbers shown are a breakdown of that 4%! So the 50% the screen used is in fact half of the 4%, which equals 2%!
    The screen is always the biggest battery guzzler, especially the white themes they insist on giving us at Google (grrrrr)!
    Getting 21 hours of of a modern smartphone is not to bad with the minuscule batteries they shoehorn into the wafer thin devices...
    04-01-2017 12:53 AM
  3. Rhyalus's Avatar
    You also need to let is settle. It is new, you are using it a lot, and it is probably updating, etc.
    Wait a week or so and see how it goes.
    R
    04-01-2017 06:48 AM
  4. delta7's Avatar
    Okay, I got this and a 6s just trying to see how it compares, the htc is unlocked straight from htc.
    04-01-2017 05:13 PM
  5. odin09's Avatar
    I get about 6 hours so good luck. When it was new I could make it through the day but now I recharge in the early afternoon.
    04-04-2017 04:37 PM
  6. mwake4goten's Avatar
    OP, what level did you put the screen brightness at? Screen brightness makes a big difference to the battery drainage. The reason why saying this is because I have to say I don't think the 10 has great battery life either unless screen brightness is minimal. But my wife's note 5 has reasonable brightness and let's longer than my 10. HTC maybe need to move to AMOLED?
    04-06-2017 06:50 AM
  1. what to do when phone charges only when turned off
    Last Post: 04-01-2017, 06:06 PM
  2. Replies: 1
  3. i am unable to connect my phone with USB TO LAPTOP
    Last Post: 04-01-2017, 05:08 AM
  4. Why my battery stuck on 1-2% when it's charge overnight?
    Last Post: 04-01-2017, 01:42 AM
  5. Snapchat crashes my sms. Trying to send snap thru sms.
    Last Post: 03-31-2017, 11:41 PM
