Results 1 to 1 of 1
- 12-25-2012, 09:05 AM
Thread Author #1
Problems with Cm7
Been reading the forums for awhile but first time post!
My problem is my htc aria is my backup phone and i have had cm7 loaded on it for a LONG time. The only problem i have with it right now is the since i have switched to it the app store will only show like 5 apps and i cant load any of the apps that was on my primary phone to my aria. Do i just need to update cm7? If do need to do this how do i go about this? Thank you for your help!
CM7 Problem With Apps
By MegaThrash in forum Software Development and HackingReplies: 1Last Post: 11-16-2011, 08:05 PM -
Problems with CM7 and force closes
By justlaxin13 in forum AT&T Captivate Rooting, ROMs, and HacksReplies: 1Last Post: 08-18-2011, 06:31 AM -
vibrate problems with aosp cm7
By wagonburner in forum Optimus V Rooting, ROMs, and HacksReplies: 6Last Post: 07-20-2011, 10:11 PM -
Problem with CM7
By robertojoven in forum Incredible Rooting, ROMs, and HacksReplies: 10Last Post: 04-17-2011, 11:16 PM -
Problems with CM7
By boyer61 in forum Motorola Droid Rooting, ROMs and HacksReplies: 6Last Post: 03-14-2011, 10:27 PM
Reply
