Results 1 to 4 of 4
- 09-12-2010, 03:01 PM
Thread Author #1
WiFi Help!
Recently got the HTC Aria. It will flawlessy connect to wifi at my job, and at my freinds house with no issues at all. at home however it wont. my network comes up (even now open) i push connect and it acts like it wants to connect in the manager, but then wifi just says "disconnected" under wifi status.
my router is currently running my wireless laptop with no issues, the router is a Netgear WGR614V9 updated to latested firmware which did nothing. Ive searched google for days trying to figure out something but nothing has happened. can anyone give me some help?? id really like to have wifi at home! - 09-12-2010, 03:27 PM #2
Do you have MAC address filtering on your router? If so, you need to add it to the list.
- 09-12-2010, 03:55 PM
Thread Author #3
- 09-13-2010, 02:06 AM #4
I had this happen on my Aria earlier today... I unplugged my wireless router and plugged it back up... once it went through the normal process and became active again my Aria picked it up and connected immediately... not sure what happened, but thats how I fixed the issue
Reply
