1. agachado's Avatar
    Is anyone else having problems syncing an Aria after rooting and installing Froyo? I am using Outlook 2007, and the sync feature worked fine with the ATT version of Android 2.1, but when I rooted and installed 2.2, it began duplicating all my calendar and contact entries on both the PC and Aria. I have worked around that by syncing only in the repair mode, and overriding everything on the phone, but it eliminates the ability to enter new contacts or appointments on the phone.
    Any ideas?
    03-09-2011 11:59 AM
