1. Raija's Avatar
    Hi!
    I've just bought a Desire and I'm really happy with my purchase :-)
    The only problem I've encountered so far is that when I connect it to my D-Link Dir-615 router it appears to be connected and the signal is strong, but I just can't use internet.
    Any idea how I can solve this? Thanks for your help!!!
    04-17-2010 06:29 PM
  2. mogune's Avatar
    Is it possible that your home Wi-Fi network is passworded?
    04-26-2010 02:48 AM
  3. LeeC22's Avatar
    As mogune said, check to see if you have any default security (WEP/WPA etc...) set up on your wireless connection (in the router). If you have, then you will need the relevant key entered into your Desire for it to work.
    Edit: Check the bottom of the router, it may just have this information on there.
    04-29-2010 07:02 AM
  4. ianst28#AC's Avatar
    I have the same problem with the same router
    The only difference is that I have a Vodafone sure signal as well
    I've spoken to Vodafone who are sure its a faulty handset (I'm not convinced)
    So far I've been waiting for 5 days for them to get the desire back in stock so I can get a replacement sent out to me (they did try to get me to accept a repair but that isn't happening)
    05-13-2010 03:23 PM
  5. dnlgee's Avatar
    Maybes Wireless Isolation could be active, therefore disabling any wireless activity unless it's allowed via inputting the MAC address of future devices you wish to connect?
    - Dan
    05-17-2010 09:57 AM
  6. ianst28#AC's Avatar
    - Dan
    ???? ok i'm deff not tech savy enough to understand anything you said there
    i managed to get a spare 20 mins and visit the local vodafone store where they tested my phone and agreed that it was definitely faulty and needed to be exchanged
    only problem is vodafone have no stock anywhere and i really dont want to swap for a different make or model ....
    05-20-2010 02:44 AM
  7. dnlgee's Avatar
    Seems nowhere have them in stock at the minute!
    05-20-2010 05:24 AM
