i've rooted my phone a while ago and had no problems with quick battery drain...it started this yesterday i unplug it from charging..and an hour later i've got one bar left..its done the same today...how do i fix this?
i should mention that theres been no incoming or outgoing texts..no calls made or recieved..and status light for incoming mail has been turned off..its just sitting there untouched...
Try fully charging. While it is plugged in, restart in Recovery. Go to the Wipe menu, then Wipe battery stats. Restart the phone; unplug as soon as you see the ROM's splash screen. Leave it unplugged until it is as close to drained as possible.
Let's see if the battery stats were bad or something.
I have a similar problem. very little uses and walla battery bout dead. Ive thought about getting an extended battery but then I wouldnt be ab le to use custom caes and such
