Results 1 to 9 of 9
    oracle646's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Weird Head Phone Icon Issue (help)
    Hey Peeps
    So I have the Eris and I look through the manual and it shows an icon that just looks like some standard phones.
    ALL though the one that I have on the phone up on the task bar is the head phone looking icon but with a mic attached. kind of like a telemarketer headset looking thing.
    The thing is i can not get rid of it and it is not listen in the manual as an icon. See i cannot hear a through the speakers assuming this is why. I even did a hard reset and it is still there.
    Anyone seen this before?
    Thanks much in advance.
    TB
  2. #2
    o2bnclemson's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Maybe a bluetooth or wireless headphone icon? Could be an option in Settings that needs to be changed. Dunno....
    oracle646's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by o2bnclemson View Post
    I hear ya, but don't know where in the settings to look. I have looked a lot of places in the settings and cannot find anything.
  4. #4
    123one's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    What I noticed on mine is when I pull out the headphones from the phone while the screen is blacked out, the phone will still think they r plugged in. If this happens, just power off the phone and turn it on again. It shouldn't have the little headphone icon on the top any more. So FYI if u unplug headphones from the phone just make sure the screen us lit up.
    oracle646's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by 123one View Post
    I even did a hard reset on the phone and the icon is still there...It is just funny when I plug in a head phone jack it take away the mic on the head phone icon, but then just makes it a standard head phone icon. When I unplug it it goes back to the head phone with a mic Icon.
  6. #6
    hazior's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Same issue
    I am having the same issue with my phone so if you find something that works please let me know.
  7. #7
    hazior's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    something small in the audio jack was the problem . . . if your still having the issue i would try blowing into the hole
  8. #8
    tropper's Avatar
    Smarty Pants
    Posts
    Global Posts
    827 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    Default
    that woulda been my guess something was bridging the gap to close the set of contacts to trigger it to run that function
  9. #9
    speeman420's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    this happened to me recently as well. don't know what the deal is, but i checked out some other forums and if you go to "Search Android Widgets" online (on your phone, of course), look for & download the "HEADSET TOGGLE WIDGET" - worked like a charm for me.
    ~hope that helps
