Hi,
I recently purchased an Incredible S for the Bell network in Canada (first android phone), it has been great except for a couple very troubling issues. The first one has been the battery life, this morning for example, since I have unplugged it for about 20 minutes, the battery life has gone down from 100% to 89%, this does not sound right. I have read online on how to improve the battery life, I reduced the screen brightness down to almost nothing, removed a bunch of widgets, turned off the gps, bluetooth and wifi radios, adjusted update schedules of apps and installed task killer to remove stop unnecessary apps from running. I have not even done any browsing of the internet or played any games, I merely read my morning emails and checked the twitter feed. I need to know if this is normal or if I have a faulty unit that I need to replace. If this is normal, how can I improve the life because this is simply not acceptable as I will have a dead battery by mid-day.
My next issue is the camera, unfortunately it has just stopped working for some unknown reason, when I click the camera icon it will either just go to a black unresponsive screen or it will quickly flash the camera icon then go back to the home screen. The only thing I could think of that perhaps caused this error is that I had installed Google Goggles, which utilizes the camera, but I have since un-installed that appand it is still not working. Once again, would it seem like I have a faulty unit? I don't know how to fix this, of course a reset has not fixed this.
Any help would be greatly appreciated, thanks in advance.
