Restore To StockRom--- Help (SOLVED)
ther1stakos
4
Hello recently i unlock and root my device, HTC EVO 3D
S-ON -
HBOOT - 1.53.007
RADIO-11.25.3504.06_M
and i can't flash any rom or anything the only rom i flash is the Cool-ICS-v13-EvoG but with no radio..
my question is:how to go to stockrom like was from the factory and what ruu i need.
i have search every forum today all day i was sitting on pc and i haven't find the correct ruu
ther1stakos
4
Re: Restore To StockRom--- Help
i have download them all and i can't find the correct ruu.
i always get error message (id model/id signature)
when i lock the device. up up in flashboot it says RELOCKED and no LOCKED
Maybe this is the problem that i can't run the ruu.exe?
p.s. i have read that s-on devices can't read the ruu zip file
benny3
Flashoholic!!
Sep 2, 2011
2,222
40
i have the same problem but it's not solved with this rom RUU_SHOOTER_U_ICS_35_S_HTC_Europe_3.28.401.1_Radio_11.77.3504.00U_11.25.3504.06_M_release_262714_signed.exe - download now for free. File sharing. Software file sharing. Free file hosting. File upload. FileFactory.com
how u solved this problem pls help me i have the same hboot and unlocked and want back to the stock rom
If you are using .exe RUU all you need to do is plug your usb cable in and run the exe from windows and it will return your phone to factory stock
joey3djamal
14
okey guys first thank you for help...... my device htc evo 3d (gsm) hboot 1.53.0007 ... unlocked ....s-on
besband version 11.77.3504.00u_11.25.3504.06_m
when i use the exe.ruu they say error 155 it's not Compatible ... so please i need the wright one can u help me...beacause i want back to the stock isc...... really thank you guys for help
cyanogen-man
1,034
7
No you need s off for the nand partition to be able to keep the custom from because it will eventually mess things up
INSPIRE AOKP ICE COLD SANDWICH ROM ;)
cyanogen-man
1,034
7
There's a GSM evo 3d? Mite be what's messing with it if they're giving you cdma ruus then yea that's going to mess with the radio for sure
benny3
Flashoholic!!
Sep 2, 2011
2,222
40
Because you are s-on your main ver. will not let you RUU back to a older version that you are currantly on. you need to find the that at matches your firmware or newer
benny3
Flashoholic!!
Sep 2, 2011
2,222
40
What about cyanogenmod ? I use eng hboot 1.04 with 2.89 firmware!
Sent from my PG86100 using Tapatalk 2
Im sure it has the VM kernel to work with 2.89
My 3d rom is built from the 2.89 FW and it also will boot from any hboot cause i had to use a different kernel
joey3djamal
14
please can you help me to find this stock rom for my device i try a lot and always the error 155... and really thank you for help
