10-14-2012 02:44 PM
52 123
tools
  1. PewDiePie's Avatar
    ok the Dl Might take awhile ok once its done Dling what do i do
    10-13-2012 01:01 AM
  2. benny3's Avatar
    when your in the recovery you should have an option like toggle usb storage , highlight it and hit power you then should be able to copy it from your pc to the sdcard
    10-13-2012 01:04 AM
  3. PewDiePie's Avatar
    its downloading what do i do after it downloads
    10-13-2012 01:06 AM
  4. benny3's Avatar
    read above your last post
    10-13-2012 01:07 AM
  5. PewDiePie's Avatar
    wow i need to install a custom recovery on my personal fone am i able to always install custom roms like this or no
    10-13-2012 01:08 AM
  6. benny3's Avatar
    once you have it copied to your sdcard find the option to install zip from sdcard /choose zip scroll down to the rom zip hit enter and it will flash the zip when its done just back out until you find the option to reboot to system it will take a little time to boot the first time so be patient
    10-13-2012 01:13 AM
  7. benny3's Avatar
    yes
    10-13-2012 01:15 AM
  8. PewDiePie's Avatar
    Its say mounting usb as storage deivice: E: unable to to write to ums lunfile
    10-13-2012 01:23 AM
  9. benny3's Avatar
    do you have a sdcard adapter to copy it from your pc? pull the sdcard out and copy from your pc
    10-13-2012 01:26 AM
  10. benny3's Avatar
    i should ask is your phone cdma or gsm?
    10-13-2012 01:29 AM
  11. PewDiePie's Avatar
    yes i do i have your clean rom on there and i got just see if its show ur rom but it doesnt show the clean rom at all
    10-13-2012 01:29 AM
  12. PewDiePie's Avatar
    Umm i dont know
    10-13-2012 01:32 AM
  13. benny3's Avatar
    did you umount the usb storage? then go to install zip from sdcard find the zip and flash it
    10-13-2012 01:34 AM
  14. benny3's Avatar
    anyways its 2:30 am and i need to be up in 4 hours to work i need some sleep, imagine that...lol hope you can get worked out. i will be on here in about 4 0r 5 hours for a bit i can check in then
    10-13-2012 01:37 AM
  15. PewDiePie's Avatar
    ok good night im about to retrry flashing
    10-13-2012 02:02 AM
  16. PewDiePie's Avatar
    well i tryed alot it not working so im going to sprint
    10-13-2012 02:37 AM
  17. benny3's Avatar
    what didnt work? will it not boot
    PewDiePie likes this.
    10-13-2012 04:00 AM
  18. pergerson6's Avatar
    Umm i dont know
    If you don't know the difference in cdma or gsm I don't think you should be trying to root.
    Sent from my PG86100 using Tapatalk 2
    10-13-2012 12:05 PM
  19. benny3's Avatar
    he said he was going to sprint so its cdma
    10-13-2012 01:19 PM
  20. PewDiePie's Avatar
    Whats Cdma and Gsm.. i have 2 Evo 3ds... both from sprint..Unlocked htc method and S-On Running Bennys Clean Rom Now
    10-13-2012 02:10 PM
  21. pergerson6's Avatar
    Gsm is at&t and t mobile's network, cdma is sprint and verizon.
    10-13-2012 02:35 PM
  22. benny3's Avatar
    i see you have it going..Great!!
    10-13-2012 03:57 PM
  23. PewDiePie's Avatar
    Yep i know there is thread with roms but it seems out of date so is thery,re any other roms out there i can flasto my Fone
    10-13-2012 04:44 PM
  24. benny3's Avatar
    you said you have hboot 1.58 and the firmware is 2.17 how did you do that with s-on? what radio do you have or baseband
    10-13-2012 06:44 PM
  25. PewDiePie's Avatar
    Did i do the impossible or something my baseband is 1.09.00.0706
    10-13-2012 08:40 PM
52 123
  1. Please Help evo 3d bricked
    By chuco10 in forum HTC EVO 3D Rooting, ROMs, and Hacks
    Last Post: 07-01-2013, 10:39 PM
  2. Help with partially bricked EVO 3D Unlocked - S-ON
    By mateo650 in forum HTC EVO 3D Rooting, ROMs, and Hacks
    Last Post: 09-28-2012, 01:15 AM
  3. Bricked Evo 3D
    By jakestucker in forum HTC EVO 3D
    Last Post: 06-13-2012, 12:25 PM
  4. Bricked Evo, A little help...?
    By jerkyxiii in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 04-10-2011, 11:58 PM
  5. Help with soft bricked evo please!
    By AlphaTango414 in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 01-13-2011, 09:29 PM
