Results 1 to 25 of 29
- 07-15-2011, 05:07 PM
Thread Author #1
Data or 3g problems. Heres the Fix. Works like heaven!
People having data connection issues: go to your dialer, enter ##3282#, select view mode, EVDO, and if Preferred Mode is not set to automatic, it was sent out with the wrong preference. Call Sprint to get your MSL code and do the same but select edit mode vs select mode, follow the same path to be able to change the selection.
Some have reported their unit with CDMA Only out of the box, and thinking many are having inconsistent data because of that.
Did this fix and perfect your phone will zip at 3gThanked by 2: - 07-16-2011, 12:14 AM #2
Re: Data or 3g problems. Heres the Fix. Works like heaven!
Night and day difference (so far). Thanks a lot for the tip. My 3G seems to be much more responsive now.
- 07-16-2011, 01:00 AM #3
- 07-16-2011, 01:18 AM #4
LOL I have my msl for a while now, so just for the kicks of it I switched mine to cdma only, and I was getting speeds of .11 lol. That is terrible. I switched it back to auto and restarted almost hit .9, .96 and 1.6 in three tries.
- 08-10-2011, 01:34 PM #5
- 08-10-2011, 02:01 PM #6
- 08-10-2011, 02:12 PM #7
- 08-10-2011, 03:16 PM #8
- 08-10-2011, 03:21 PM #9
Mine too is set to auto. Still very slow 3g.
What gives? - 08-11-2011, 11:10 AM #10
I did this and no luck. Im in a roaming zone, up untill two days ago it worked great still, then now it seems like I dont have a 3G download. I do see the 3G sign and the up arrow flasshing but no down arrow. It also shows full bars. What gives? I tried Roam Control and doesnt seem to make a difference.
I receive calls, text, pictures and GPS signal no problem. - 08-11-2011, 12:01 PM #11
- 08-11-2011, 12:24 PM #12
Cant do a speedtest at the time because it seems the network is not giving me back a data signal, the upload 3G arrow flashes but no download arrow on top of the screen. Tried to do the Profile Update and the PRL and no luck (which is what the sprint tech told me to do). Phone calls and all are great, just no data. Two days ago it was all good and im in the same location.
- 08-11-2011, 01:38 PM #13
- 08-11-2011, 02:52 PM #14
Nah i wish, Brooklyn is home but im statione elsewere now. I was having good signal and speed and then this issue happened from before yesterday on. Since I last wrote I was able to get data for a few minutes out of luck and even did the hotspot to my xoom. I dont get it, it does have full bars most of the time.
- 08-11-2011, 03:30 PM #15
- 08-11-2011, 04:08 PM #16
- 08-11-2011, 04:25 PM #17
maps, navigation, and such use your GPS radio, not your 3G radio.
internet is another story. try to update your PRL. this may give your phone a new set of towers to roam on.
if this doesn't work, then it might be time to call Sprint's tech suport. - 08-11-2011, 06:47 PM #18
- 08-11-2011, 07:15 PM #19
I'm having the same problems that Viper is having. For me I'm pretty sure it is tied directly to roaming because the building I work in seems to do a very good job of blocking out Sprint's signals but seems to not have the same effect on Verizon's. When I first got the phone I started using Roam Control to keep my phone on roaming so as not to lose the good data connection. It worked fine for the first week or so. Now I end up getting the same problem of either 3g not showing up at all or only getting the arrow pointing upward, but not downward (indicating that I'm receiving data).
The other thing I've noticed is that my phone seems to be changing my roaming settings from "Automatic" to "Sprint Only". I'll go in and change it, but the options keeps getting switched back somehow.
So confused. Either way, when I am getting a Sprint signal everything seems to work fine. - 08-11-2011, 10:32 PM #20
- 08-12-2011, 09:49 AM #21
Alphalog80 my Roaming setting did change probably twice to "sprint only" and i changed it back to "automatic" and check so often to make sure it didnt change back. Warpdrive I kinda have the same feeling as you, thinking its sprint itself limiting the roaming. I do have the everything plan so it would be messed up of them to do so. I receive calls text and gps signal well, even have a clear 3G on the top bar with the up arrow lit white, but just no down arrow and not receiving data. Phone is not rooted or any hack, and I didnt have a problem before roaming in any states. The 4G when I had it in some places was awesome though.
- 08-12-2011, 10:51 AM #22
I fly to williston, nd everyday and my data isn't working either. Something happened this seem in the state of ND because I lost data roaming on monday and so did my wife. Calling sprint does no good because they won't guarantee data roaming and come up with all kinds of excuses
Sent from my PC36100 using Tapatalk - 08-12-2011, 11:39 AM #23
Exactly, I was on the phone three different times, they try to do a profile/PRL updadate and neither connects. The phone service hast changed at least.
UPDATE: Phone still wont connect to the internet for web browsing, updating e-mail ect... but it work to do hotspot. So I can connect my xoom to it and its fairly quick, but the phone itself wont use internet.Last edited by XxViperNYCxX; 08-12-2011 at 02:24 PM.
- 08-12-2011, 02:31 PM #24
I'm runnin on 1.8Mbit using my airave and I have that setting already on "auto".
What rates should I be getting? Thanks for the tip! - 08-12-2011, 02:48 PM #25
Here in Indy, I've only been averaging .05 down and .07 up. I had the problem on my old EVO, and my dad's phone does the same thing. I think it's the area, and I wish it was just something recent and for a short time, but it's been going on for 2 months or so. I think it's time to call sprint and complain.
Reply
