Results 1 to 6 of 6
    mtmjr90's Avatar
    Posts
    Global Posts
    658 Global Posts
    ROM
    Stock (for now)
    Default Overheating and poor battery?
    Hey guys,
    I've noticed over the past week or so that my battery has gotten absolutely abysmal. It started out just fine when I got my 3D, but now it drops 50% in 4 hours when all I've done is read a couple emails and send a few texts. Otherwise, all it does is sit there. Additionally, after a 10 minute phone call, I'll notice the battery has dropped about 10-15%. Is this happening to anyone else?
    In conjunction with all this, I've noticed the phone has been getting very warm (not HOT, but quite warm) while charging and while I'm on a call.
    I'm thinking the two issues might be related, but all HTC tech support did was advise me to turn off wi-fi, reduce screen brightness, blah blah blah. I had an Evo 4G, so I know how to conserve battery, but this doesn't seem right. Any thoughts? Thanks!
    -Mike
  2. #2
    Default
    Same exact thing is happening to me
    Sent from my PG86100 using Tapatalk
  3. #3
    tkemack's Avatar
    Posts
    ROM
    Blazer ROM/Stock Kernel
    Default
    I would recommend getting the app "watch dog". You can see, in detail, what is running. I suspect it is an app you downloaded. For instance, I had tweetcaster until I realized it was taking 30-40% of CPU usage when not even in use. Poorly written apps can easily kill a battery.
    sent to you in three dimensions
  4. #4
    huix0018's Avatar
    Posts
    Global Posts
    173 Global Posts
    Default Re: Overheating and poor battery?
    my battery is fine but the overheating is problem. especially when the camera app is on.
    mtmjr90's Avatar
    Posts
    Global Posts
    658 Global Posts
    ROM
    Stock (for now)
    Default
    Thanks. I'll give watchdog a trybamd see what happens.
    Sent from my HTC Evo 3D using Tapatalk
  6. #6
    I have EVO 3d. Same problems. Called HTC today & having replacement battery sent. Did not put up with a lot of blah blah blah. If problems persist will look elsewhere for solutions. Good luck
