Results 1 to 12 of 12
    Default Asphalt 6 3D using up my battery even when the game isn't running
    Hi there,
    I downloaded Aspalt6 3D at the end of last week but have noticed that even when it hasn't been played it is causing significant battery drain.
    Below is a two screenshots I just took. The battery was charged this morning and the game hasn't been played for a few days. I noticed it was using battery yesterday but checked and it wasn't running then either.
    As you can see my phone has had very little use since it came off the charger 2 hours ago. Can anyone tell if there is something I should be doing to kill the application? I didn't have to press force stop as it wasn't highlighted.
    Thanks
    Stevie
  2. #2
    Default Re: Asphalt 6 3D using up my battery even when the game isn't run
    I was having the same problem (with asphalt 6) the only thing that worked for me was restarting the phone...
    Thanks, I'll give that a go.
  4. #4
    tkemack's Avatar
    Posts
    ROM
    Blazer ROM/Stock Kernel
    Default
    I have this same issue though it is currently taking up 16% of my battery. Just got the game 2 days ago from my 3d but have had it for my galaxy tab for a month and no issues there. Restarting phone now
    sent to you in three dimensions
    I tried the restart but unfortunately it still accounted for approximately 15% of battery life over the total charge (I get a day out of the charge) even though the game was never run.
    Anybody else having this problem?
    Thanks
    Stevie
    I've just emailed Gameloft for an explanation. I'll let you know if I get a response.
    Stevie
    UPDATE: After another restart this morning after spending the night on the charger Asphalt6 hasn't used any battery up. Hopefully that is the problem cured but I haven't run the app.
    Stevie
  8. #8
    Default
    Use advance task killer to see what's running. If you're sure it is killing the battery it'll probably show up on atk's list, then juat kill app.
    Sent from HTC Evo 3D using Tapatalk
  9. #9
    I noticed the same thing, Asphalt 6 3D shows in battery usage statistics even when I'm not using it; I haven't noticed an increase in battery drainage though.
  10. #10
    Quote Originally Posted by madmax2k1 View Post
    That's it! The game does not actually drain the battery but it still displays on the battery usage status which should be fixed if you will update to the latest Android Firmware version.
  11. #11
    Quote Originally Posted by Nikita2011 View Post
    while I haven't played the game in a week, it is no longer listed in my battery app anymore after the update.
    I'll test it for sure later and reprt back if it stays listed.
  12. Thread Author  Thread Author    #12
    I haven't had any problems since either. Sorted for now!
