1. LegendaryDolphins's Avatar
    I recently installed a kernel to get a JB rom and it updated my HBOOT to 1.19 so no I'm on 1.19 and s-on and can't use any Roms to my knowledge. I found someone that was in the same situation but he has the latest ruu, i tried contacting him but had no luck. I only have access to the HBOOT and the recovery if I try to start up the system it gets stuck in a boot loop. So please someone help me.
    10-31-2012 11:14 PM
  2. benny3's Avatar
    Did you make a backup before flashing?...Rule # 1
    LegendaryDolphins likes this.
    10-31-2012 11:18 PM
  3. LegendaryDolphins's Avatar
    Yea but somehow it got lost and isn't there anymore.
    10-31-2012 11:23 PM
  4. benny3's Avatar
    it should be your sdcard, anyhow a kernel should not have done anything to your hboot. what exactly did you flash?
    10-31-2012 11:26 PM
  5. LegendaryDolphins's Avatar
    I flashed a kernel by komodo that was meant for an s-off evo
    10-31-2012 11:40 PM
  6. benny3's Avatar
    did you flash a rom? if not flash the boot.img from the rom you were on with fastboot
    10-31-2012 11:44 PM
  7. LegendaryDolphins's Avatar
    I tried but I would get stuck in a boot loop. Where do i get the boot.img from?
    10-31-2012 11:49 PM
  8. benny3's Avatar
    You can go HERE and use one of these they work with stock based roms. I recommend using the 1.89
    11-01-2012 04:55 AM
  9. LegendaryDolphins's Avatar
    Right before I reboot my phone it says I don't have an OS installed.
    11-02-2012 12:57 AM
  10. benny3's Avatar
    I would say reflash your rom
    11-02-2012 04:33 PM
  11. LegendaryDolphins's Avatar
    I'm trying that right now, do you know how to flash an RUU without having an os? Like flashing it through recovery somehow, because I think it might be the RUU.
    11-02-2012 07:54 PM
  12. benny3's Avatar
    Check your PM
    11-02-2012 11:23 PM
  13. thaddious's Avatar
    you got that ruu? if youd like to share
    03-22-2014 07:37 PM
  14. thaddious's Avatar
    Do you have a link to the ruu for the evo LTE on hboot 1.19?
    think i am in a soft brick.... plz help
    03-22-2014 07:39 PM
  1. Please help! Htc evo 4g is stuck on green arrow screen!!
    By squeakywheel in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 08-14-2012, 03:55 PM
  2. NOOB needs help...HTC EVO 4g stuck in bootloop
    By geohiker in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 08-02-2012, 04:10 AM
  3. Please help! Htc evo 4g is stuck on green arrow screen!!
    By squeakywheel in forum Software Development and Hacking
    Last Post: 06-29-2012, 10:50 AM
  4. Replies: 3
    Last Post: 12-15-2011, 03:41 PM
  5. I need help please evo 4g bricked
    By alex1806 in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 06-17-2011, 09:55 AM
