01-07-2013 10:28 PM
36 12
tools
  1. benny3's Avatar
    CleanROM BE 2.3 i sent the link in the PM yesterday, it will flash the boot.img for with the script i have in it
    http://db.tt/EO70Uo5B
    LegendaryDolphins likes this.
    11-03-2012 05:40 PM
  2. benny3's Avatar
    Well how's it going?
    11-03-2012 06:44 PM
  3. LegendaryDolphins's Avatar
    I rooted my phone and when you said to use the app to flash the boot img. of the rom do you mean to select the rom .zip file and then go into recovery to flash the whole rom? Because I was thinking of flashing
    CM10
    [10-29-12][ROM] CM10 for the evoLTE! - butta! - xda-developers
    or
    Paranoid Android
    [ROM] Paranoid Android [2.51] JB 4.1.2 Unofficial Updated! - xda-developers
    11-03-2012 07:35 PM
  4. benny3's Avatar
    put the rom on your sdcard, open the app flashimage gui and make sure the kernel image option is checked click the browse button find the rom you want to flash then click the flash image button. when its done it will ask if you want to reboot to recovery tell it yes. then in recovery install the rom and you should be good to go
    11-03-2012 07:52 PM
  5. benny3's Avatar
    One more thing do a nand backup while in recovery before you flash anything
    11-03-2012 08:02 PM
  6. LegendaryDolphins's Avatar
    Awesome!!! Thank you sooooo much!!!
    11-03-2012 08:02 PM
  7. benny3's Avatar
    I take it everything worked out ok
    11-04-2012 01:29 PM
  8. bigboy_24's Avatar
    Does this work with hboot 1.15
    12-31-2012 08:20 PM
  9. benny3's Avatar
    Does what work on 1.5 ?
    12-31-2012 08:34 PM
  10. mick3444's Avatar
    I'm new to the evo and had one quick question. Do you need to have s-off to flash the jellybean roms that have been talked about? Or do you just need root and twrp installed?
    01-07-2013 09:18 PM
  11. benny3's Avatar
    You need to unlock the bootloader and install twrp and flash the rom. the rom will be rooted so no need to worry about root. But if your not s-off you will need to flash the boot.img with either fastboot or a third party app like FlashImage GUI from the playstore. Some roms will use a script that will flash it also
    01-07-2013 10:28 PM
36 12
  1. Pre-ordered my phone... need help setting up
    By neoenigma in forum HTC One X
    Last Post: 05-04-2012, 01:35 PM
  2. Hoping I didnt brick my phone, NEED HELP!
    By Casutherland42 in forum AT&T Inspire 4G
    Last Post: 06-01-2011, 11:35 AM
  3. [RESOLVED] OMG Bricked my phone, need help!
    By deathbytampon in forum Verizon Fascinate Rooting, ROMs, and Hacks
    Last Post: 05-10-2011, 06:41 AM
  4. Can I use my phone as a wifi webcam for video chat?
    By whitenack in forum General Help and How To
    Last Post: 07-05-2010, 10:03 PM
  5. Sense = Force Close!!! Help, can't use my phone.
    By Ter1990 in forum HTC Droid Eris
    Last Post: 01-23-2010, 03:47 PM
