01-07-2013 10:28 PM
36 12
tools
  1. LegendaryDolphins's Avatar
    So I recently tried to install a Jelly Bean ROM so I decided to flash a new kernel by komodo and ever since that I can't start up a ROM because I get stuck in a boot loop. All I have access to is recovery and HBOOT. When I'm in HBOOT this is what I see if this might help you. I'm also on recovery v2.2.2.
    *** TAMPERED ***
    *** UNLOCKED ***
    JEWEL PVT SHIP S-ON RL
    HBOOT-1.19.0000
    RADIO-1.12.11.0809
    OpenDSP-v29.1.0.45.0622
    eMMC-boot
    Aug 9 2012,15:14:25
    Please if you know what's wrong and can help me reply or pm me. Thank you.
    11-03-2012 02:12 AM
  2. benny3's Avatar
    I see you started another thread,,Anyways , lets run a RUU, If you have the .exe, make sure you have the latest DRIVERS installed on your pc. Boot the phone to recovery with the phone plugged into the usb and and run the .exe
    Make sure you download RUU_JEWEL_CLICS_40_S_Sprint_WWE-2.13.651.1_Radio_1.12.11.0809_NV_SPCS-2.45_003_release_277028_signed.exe
    LegendaryDolphins and newboyx like this.
    11-03-2012 04:17 AM
  3. BlackHawkA4's Avatar
    *** TAMPERED ***
    *** UNLOCKED ***
    HBOOT-1.19.0000
    RADIO-1.12.11.0809
    eMMC-boot
    Aug 9 2012,15:14:25
    If you made a backup flash your backup and the phone will work.
    Otherwise or even after you do that you need fast boot to flash the boot.IMg. the boot doesn't flash with thar hboot.
    LegendaryDolphins likes this.
    11-03-2012 10:54 AM
  4. LegendaryDolphins's Avatar
    I went into recovery but it said it wasn't connected even though i had it mounted, was i suppose to do anything specific in recovery so the exe can recognize my phone.
    benny3 likes this.
    11-03-2012 11:11 AM
  5. benny3's Avatar
    Dont mount anything just stay on the main screen
    11-03-2012 01:47 PM
  6. LegendaryDolphins's Avatar
    I get error 170 saying it's not connected.
    11-03-2012 01:58 PM
  7. benny3's Avatar
    do you know to pull the rom.zip from the .exe?
    Edit: do you have sdk or at least fastboot and adb installed on your pc?
    11-03-2012 02:09 PM
  8. LegendaryDolphins's Avatar
    No and no I never needed to any of that until now.
    benny3 likes this.
    11-03-2012 02:14 PM
  9. benny3's Avatar
    Download this and extract the folder to your desktop
    http://beta.androidfilehost.com/?fid...35922294523275
    11-03-2012 02:24 PM
  10. benny3's Avatar
    Let me know when you have that finished cuz we need to relock your bootloader
    11-03-2012 02:44 PM
  11. LegendaryDolphins's Avatar
    Now what?
    11-03-2012 02:47 PM
  12. benny3's Avatar
    ok plug your phone in and reboot it into the bootloader, when it does make sure you have fastboot usb highlighted, if it is then on you pc , hold down the shift key right click on the folder you extracted to your desktop and click on open command prompt from here
    In the cmd window type this fastboot oem lock
    11-03-2012 02:51 PM
  13. benny3's Avatar
    Then you need to download this....http://db.tt/hN1pALK8 and put it on your sdcard and not in any folder
    Also let me know if it says locked or relocked at the top in the bootloader
    11-03-2012 02:53 PM
  14. LegendaryDolphins's Avatar
    Done now what? Do i go into recovery to put the zip. in
    benny3 likes this.
    11-03-2012 02:54 PM
  15. LegendaryDolphins's Avatar
    I't says it's relocked
    benny3 likes this.
    11-03-2012 02:59 PM
  16. benny3's Avatar
    yes go into recovery and choose mount usb storage and copy the PJ75IMG over then choose reboot to bootloader. it should find the zip you just put on there and ask if you want to update, should be volume up for yes
    11-03-2012 03:02 PM
  17. LegendaryDolphins's Avatar
    It wouldn't let me go into recovery so i just took the sd card out and plugged it into my pc, about to do the update.
    benny3 likes this.
    11-03-2012 03:04 PM
  18. LegendaryDolphins's Avatar
    Ok it's done updating
    benny3 likes this.
    11-03-2012 03:21 PM
  19. benny3's Avatar
    just scroll down to reboot and hit power
    Let me know when it boots up
    11-03-2012 03:25 PM
  20. LegendaryDolphins's Avatar
    Ok it rebooted and I'm back to stock is there anything else I need to do?
    benny3 likes this.
    11-03-2012 03:31 PM
  21. benny3's Avatar
    what are you wanting to do?
    11-03-2012 03:32 PM
  22. LegendaryDolphins's Avatar
    I wan't to be able to install a Jelly Bean ROM or any of the other sense based roms that are on the latest RUU, for that would I have to do the RUU thing on the pc and I was wondering if I was still rooted or not.
    11-03-2012 03:35 PM
  23. benny3's Avatar
    no your not rooted you are back to factory stock, you will need to go through the Welcome to HTCdev again to unlock your bootloader and then install twrp again
    you should not need to install sdk just use the fastboot and adb from the folder on your desktop
    One more thing, get that PJ75IMG off your sdcard or rename it , if not it will want to update every time you enter the bootloader
    11-03-2012 03:39 PM
  24. benny3's Avatar
    If you still have my rom or the link flash that in recovery, that will give you root. then get this off the playstore FlashImage GUI it cost a dollar but it will flash the boot.img from the rom you want to flash. use the app to flash the boot.img before you flash the rom then you can go into recovery and flash the zip
    11-03-2012 04:08 PM
  25. LegendaryDolphins's Avatar
    Which rom and I might need help with all of this.
    11-03-2012 05:12 PM
36 12
  1. Pre-ordered my phone... need help setting up
    By neoenigma in forum HTC One X
    Last Post: 05-04-2012, 01:35 PM
  2. Hoping I didnt brick my phone, NEED HELP!
    By Casutherland42 in forum AT&T Inspire 4G
    Last Post: 06-01-2011, 11:35 AM
  3. [RESOLVED] OMG Bricked my phone, need help!
    By deathbytampon in forum Verizon Fascinate Rooting, ROMs, and Hacks
    Last Post: 05-10-2011, 06:41 AM
  4. Can I use my phone as a wifi webcam for video chat?
    By whitenack in forum General Help and How To
    Last Post: 07-05-2010, 10:03 PM
  5. Sense = Force Close!!! Help, can't use my phone.
    By Ter1990 in forum HTC Droid Eris
    Last Post: 01-23-2010, 03:47 PM
