1. donrhummy's Avatar
    I've been using CM10 for about 4-5 days on an HTC Evo 4G LTE (and tried reflashing gapps and CM10) and I've come across the following problem:
    1. When I start Navigation, it takes a long time to get a lock
    2. It holds the lock for about 2-3 minutes at most and then loses signal (never did this with HTC Sense)
    I've got the "use internal" checked.
    Has anyone else experienced this and found a fix?
    12-27-2012 09:42 AM
  2. benny3's Avatar
    You might get a better answer asking the dev or in the thread where you downloaded it
    12-27-2012 12:27 PM
  3. donrhummy's Avatar
    ??? It's cyanogenmod 10.
    12-27-2012 05:22 PM
  4. benny3's Avatar
    But who's version or port, i dont think cyanogenmod supports are device
    CyanogenMod Forum
    12-27-2012 08:16 PM
  5. donrhummy's Avatar
    CyanogenMod Forum
    The official one. Yes, they do support it:
    CyanogenMod Downloads for HTC Evo 4G LTE (Jewel)
    You'll see they have a "stable" version as well as nightlies.
    12-28-2012 12:07 PM
  6. mstrblueskys's Avatar
    Which version are you on?
    12-28-2012 01:53 PM
  7. benny3's Avatar
    Go to the link i posted. there is not any support for the device
    12-28-2012 07:35 PM
  8. Va1ha11a's Avatar
    Kushdeck makes builds that are on get.cm (as well as xda), i don't know why the LTE isn't showing up as supported. Here's the xda link:
    [12-4-12][ROM] CM10 for the evoLTE! - butta! - xda-developers
    benny3 likes this.
    12-29-2012 08:28 PM
  9. benny3's Avatar
    I wont run cm on anything i have buts thats just me
    i dont think CyanogenMod supports the LTE officially , im like you i dont know why
    12-29-2012 09:54 PM
  10. donrhummy's Avatar
    Thanks for the link but I don't feel comfortable putting on software (ROM or otherwise) that's just posted in a forum. I prefer an established, trusted source like CM's official get.cm. Do you know where I can find a list of things working/not working in each nightly version by CM?
    12-29-2012 11:41 PM
  11. benny3's Avatar
    Kushdeck is a well known developer in the world of android and is very well trusted. He even works with CM on thier development
    Va1ha11a likes this.
    12-30-2012 10:42 AM
  12. Va1ha11a's Avatar
    If you prefer, CyanogenMod Downloads. The only difference between this and the xda builds are that the xda builds are updated less frequently, but deck fixes the xda builds first, and than later merges the fixes into cm's github tree. (a bot churns out the cm nightlies, regardless of actual fixes submitted)
    +1. Deck is a well known and trusted developer.
    benny3 likes this.
    01-02-2013 05:24 PM
  1. RSD Lite does not recognize the device
    By dalvik in forum AT&T ATRIX
    Last Post: 09-28-2016, 07:00 PM
  2. GPS does not work, and where is wifi calling?
    By bigDeeOT in forum Google / Samsung Galaxy Nexus
    Last Post: 02-02-2012, 03:09 PM
  3. How to hold the EVO in Roaming
    By ianmac23 in forum HTC EVO 3D
    Last Post: 08-10-2011, 02:50 PM
  4. 3G/4G Indicator does not relate to Signal Strength!
    By FrankXS in forum Verizon HTC Thunderbolt
    Last Post: 07-07-2011, 06:03 PM
  5. Replies: 4
    Last Post: 06-04-2011, 04:18 PM
