For all of you who are wanting to root the Evo 4G LTE with the new update 1.22.651.3 There is an easy method I have tested it with my phone and have done it on 5 of my friends phones here are the steps you need to do.
First off I did not make any of these rooting tools regaw_leinad did credit credit goes to him
Requirements
Windows Computer
HTC Drivers installed
.NET 4.0 installed
Active Internet Connection (for communication with HTCdev.com)
First you need to download these files first one is RegawMOD EVO 4G LTE Rooter for either 32bit or 64bit windows also you need to download the drivers for your phone.
Link here [ROOT] RegawMOD EVO 4G LTE Rooter | Updated 06.13.12 - xda-developers Read there instructions there to use this... NOTE: Unlocking your bootloader erases ALL user data on the phone! Be sure to back up!
2nd file Evo4GLTERoot2.zip can be found here Download HTCEvo4GLTE/rooting at DownloadAndroidROM.com
First step BACK UP RegawMOD will unlock the boot loader and resets your phone
Make sure you on the 1.22.651.3 if not update to it...
Install the Drivers and Net 4.0 if you don't have it
Then run the RegawMOD file follow instructions on screen It will unlock the boot loader reset the phone and install the custom recovery It will fail when it tries to do the root. this was made for the older software version this is ok ignore the failure... It will still unlock the boot loader and install the custom recovery.
Now you need to unzip the Evo4GLTERoot2.zip file inside this file you will find one called CWM-SuperSU-v0.87.zip move this file to the root of your SD card (internal)
Go in to recovery browse to the file and install it then reboot your now rooted
If you having a prob you may need to change your firewall settings and or disable your anti virus program confirmed works fine with avast
ENJOY
Requirements
Windows Computer
.NET 4.0 installed
ENJOY
