Results 1 to 3 of 3
    321contak's Avatar
    Posts
    Global Posts
    91 Global Posts
    Default Regamod root issue/problem
    Hello again,
    I wanted to reset my phone to factory stock and get the latest updates and then root again.
    This is what I did:
    1. Unrooted with the RUU Method: Worked Excellent. Thanks to XDA, QBKing77
    2. Downloaded and Installed latest OTA updates
    3. Tried to root again using REGAMOD method following QBKing77 and djR3Z- Video instructions. Excellent videos BUT:
    During the Regamod process my phone did not go to the boot loader automatically.
    I had to power down and manually do go into boot loader every step it was required to. When all was done my boot load screen showed the correct information at the top: "TAMPERED" and "UNLOCKED" .
    I was also able to go to RECOVERY and TWRP recovery was there.
    I thought everything was ok so I powered down and restarted my phone.
    When I went into the app menu to see if SUPER SU was installed, it was not there???
    I went to the Play store and downloaded it and started the app but it said "No Binary Installed"
    I used ROOT CHECKER app and it said phone is not rooted.
    I have no idea what went wrong but the main issue was during the Regamod running, my phone just stayed idle and never went into the Bootloader automatically as it should have.
    Can someone please advise and send me some help?
    Thanks
  2. #2
    gitit20's Avatar
    Posts
    Global Posts
    1,234 Global Posts
    ROM
    Ace Rom 1.7 / ACS 1.2
    Default
    You have to download and flash the Su bianery In twrp then you will have root
    Quote Originally Posted by 321contak View Post
    Hello again,
    This is what I did:
    Thanks
    Thanked by:
    321contak's Avatar
    Posts
    Global Posts
    91 Global Posts
    Default Re: Regamod root issue/problem
    Thanks gitit20
    Are you saying that:
    I will be able to install just TWRP first?
    Then use Regamod to Root?
    If you can provide steps, that would help me out tremendously.
    Thanks again for your help
  1. Samsung Vibrant root/lagfix problem...
    By AnAm85 in forum Software Development and Hacking
    Last Post: 09-26-2010, 09:14 PM
  2. One rooting issue.
    By sharpma in forum Incredible Rooting, ROMs, and Hacks
    Last Post: 08-19-2010, 03:32 PM
  3. Evo Notification Bar issues/problem
    By zoo32 in forum HTC EVO 4G
    Last Post: 08-12-2010, 08:33 AM
  4. Eris Rooting Issue.
    By rufioxiii in forum HTC Droid Eris
    Last Post: 05-04-2010, 10:04 PM
  5. Ok. What is going on with the root issue
    By Sbkillz in forum HTC Droid Eris Rooting, ROMs, and Hacking
    Last Post: 01-14-2010, 02:15 PM
B
