Results 1 to 12 of 12
    Default HBOOT 1.19 S-ON Need HELP!!! HTC EVO 4G LTE
    I recently installed a kernel to get a JB rom and it updated my HBOOT to 1.19 so no I'm on 1.19 and s-on and can't use any Roms to my knowledge. I found someone that was in the same situation but he has the latest ruu, i tried contacting him but had no luck. I only have access to the HBOOT and the recovery if I try to start up the system it gets stuck in a boot loop. So please someone help me.
  2. #2
    benny3's Avatar
    Flashoholic!!
    Posts
    ROM
    Sense 5 Port
    Default Re: HBOOT 1.19 S-ON Need HELP!!! HTC EVO 4G LTE
    Did you make a backup before flashing?...Rule # 1
    If i Helped Please Hit The Thanks And Like Button
    Thanked by:
    Yea but somehow it got lost and isn't there anymore.
  4. #4
    benny3's Avatar
    Flashoholic!!
    Posts
    ROM
    Sense 5 Port
    it should be your sdcard, anyhow a kernel should not have done anything to your hboot. what exactly did you flash?
    Thanked by:
    I flashed a kernel by komodo that was meant for an s-off evo
  6. #6
    benny3's Avatar
    Flashoholic!!
    Posts
    ROM
    Sense 5 Port
    did you flash a rom? if not flash the boot.img from the rom you were on with fastboot
    Thanked by:
    I tried but I would get stuck in a boot loop. Where do i get the boot.img from?
  8. #8
    benny3's Avatar
    Flashoholic!!
    Posts
    ROM
    Sense 5 Port
    You can go and use one of these they work with stock based roms. I recommend using the 1.89
    Thanked by:
    Right before I reboot my phone it says I don't have an OS installed.
  10. #10
    benny3's Avatar
    Flashoholic!!
    Posts
    ROM
    Sense 5 Port
    I would say reflash your rom
    Thanked by:
  11. Thread Author  Thread Author    #11
    I'm trying that right now, do you know how to flash an RUU without having an os? Like flashing it through recovery somehow, because I think it might be the RUU.
  12. #12
    benny3's Avatar
    Flashoholic!!
    Posts
    ROM
    Sense 5 Port
    Check your PM
  1. Please help! Htc evo 4g is stuck on green arrow screen!!
    By squeakywheel in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 08-14-2012, 03:55 PM
  2. NOOB needs help...HTC EVO 4g stuck in bootloop
    By geohiker in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 08-02-2012, 04:10 AM
  3. Please help! Htc evo 4g is stuck on green arrow screen!!
    By squeakywheel in forum Software Development and Hacking
    Last Post: 06-29-2012, 10:50 AM
  4. Replies: 3
    Last Post: 12-15-2011, 03:41 PM
  5. I need help please evo 4g bricked
    By alex1806 in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 06-17-2011, 09:55 AM
