Page 1 of 2 12 LastLast
Results 1 to 25 of 36
Like Tree18Likes
    Default Can't use my phone Need Help!!!
    So I recently tried to install a Jelly Bean ROM so I decided to flash a new kernel by komodo and ever since that I can't start up a ROM because I get stuck in a boot loop. All I have access to is recovery and HBOOT. When I'm in HBOOT this is what I see if this might help you. I'm also on recovery v2.2.2.
    *** TAMPERED ***
    *** UNLOCKED ***
    JEWEL PVT SHIP S-ON RL
    HBOOT-1.19.0000
    RADIO-1.12.11.0809
    OpenDSP-v29.1.0.45.0622
    eMMC-boot
    Aug 9 2012,15:14:25
    Please if you know what's wrong and can help me reply or pm me. Thank you.
  2. #2
    benny3's Avatar
    Flashoholic!!
    Posts
    ROM
    Sense 5 Port
    Default Re: Can't use my phone Need Help!!!
    I see you started another thread,,Anyways , lets run a , If you have the .exe, make sure you have the latest installed on your pc. Boot the phone to recovery with the phone plugged into the usb and and run the .exe
    Make sure you download RUU_JEWEL_CLICS_40_S_Sprint_WWE-2.13.651.1_Radio_1.12.11.0809_NV_SPCS-2.45_003_release_277028_signed.exe
    If i Helped Please Hit The Thanks And Like Button
    Thanked by 2:
    newboyx and LegendaryDolphins like this.
  3. #3
    BlackHawkA4's Avatar
    Drop the Bag
    Posts
    Global Posts
    2,420 Global Posts
    Default
    Quote Originally Posted by LegendaryDolphins View Post
    *** TAMPERED ***
    *** UNLOCKED ***
    HBOOT-1.19.0000
    RADIO-1.12.11.0809
    eMMC-boot
    Aug 9 2012,15:14:25
    If you made a backup flash your backup and the phone will work.
    Otherwise or even after you do that you need fast boot to flash the boot.IMg. the boot doesn't flash with thar hboot.
    Thanked by:
    LegendaryDolphins likes this.
    I went into recovery but it said it wasn't connected even though i had it mounted, was i suppose to do anything specific in recovery so the exe can recognize my phone.
    Thanked by:
    benny3
  5. #5
    benny3's Avatar
    Flashoholic!!
    Posts
    ROM
    Sense 5 Port
    Dont mount anything just stay on the main screen
    Thanked by:
    I get error 170 saying it's not connected.
  7. #7
    benny3's Avatar
    Flashoholic!!
    Posts
    ROM
    Sense 5 Port
    do you know to pull the rom.zip from the .exe?
    Edit: do you have sdk or at least fastboot and adb installed on your pc?
    Thanked by:
  8. Thread Author  Thread Author    #8
    No and no I never needed to any of that until now.
    Thanked by:
    benny3
  9. #9
    benny3's Avatar
    Flashoholic!!
    Posts
    ROM
    Sense 5 Port
    Download this and extract the folder to your desktop
    Thanked by:
  10. #10
    benny3's Avatar
    Flashoholic!!
    Posts
    ROM
    Sense 5 Port
    Let me know when you have that finished cuz we need to relock your bootloader
    Thanked by:
  11. Thread Author  Thread Author    #11
    Now what?
  12. #12
    benny3's Avatar
    Flashoholic!!
    Posts
    ROM
    Sense 5 Port
    ok plug your phone in and reboot it into the bootloader, when it does make sure you have fastboot usb highlighted, if it is then on you pc , hold down the shift key right click on the folder you extracted to your desktop and click on open command prompt from here
    In the cmd window type this fastboot oem lock
    Thanked by:
  13. #13
    benny3's Avatar
    Flashoholic!!
    Posts
    ROM
    Sense 5 Port
    Then you need to download this.... and put it on your sdcard and not in any folder
    Also let me know if it says locked or relocked at the top in the bootloader
    Thanked by:
  14. Thread Author  Thread Author    #14
    Done now what? Do i go into recovery to put the zip. in
    Thanked by:
    benny3
  15. Thread Author  Thread Author    #15
    I't says it's relocked
    Thanked by:
    benny3
  16. #16
    benny3's Avatar
    Flashoholic!!
    Posts
    ROM
    Sense 5 Port
    yes go into recovery and choose mount usb storage and copy the PJ75IMG over then choose reboot to bootloader. it should find the zip you just put on there and ask if you want to update, should be volume up for yes
    Thanked by:
  17. Thread Author  Thread Author    #17
    It wouldn't let me go into recovery so i just took the sd card out and plugged it into my pc, about to do the update.
    Thanked by:
    benny3
  18. Thread Author  Thread Author    #18
    Ok it's done updating
    Thanked by:
    benny3
  19. #19
    benny3's Avatar
    Flashoholic!!
    Posts
    ROM
    Sense 5 Port
    just scroll down to reboot and hit power
    Let me know when it boots up
    Thanked by:
  20. Thread Author  Thread Author    #20
    Ok it rebooted and I'm back to stock is there anything else I need to do?
    Thanked by:
    benny3
  21. #21
    benny3's Avatar
    Flashoholic!!
    Posts
    ROM
    Sense 5 Port
    what are you wanting to do?
    Thanked by:
  22. Thread Author  Thread Author    #22
    I wan't to be able to install a Jelly Bean ROM or any of the other sense based roms that are on the latest RUU, for that would I have to do the RUU thing on the pc and I was wondering if I was still rooted or not.
  23. #23
    benny3's Avatar
    Flashoholic!!
    Posts
    ROM
    Sense 5 Port
    no your not rooted you are back to factory stock, you will need to go through the again to unlock your bootloader and then install twrp again
    you should not need to install sdk just use the fastboot and adb from the folder on your desktop
    One more thing, get that PJ75IMG off your sdcard or rename it , if not it will want to update every time you enter the bootloader
    Thanked by:
  24. #24
    benny3's Avatar
    Flashoholic!!
    Posts
    ROM
    Sense 5 Port
    If you still have my rom or the link flash that in recovery, that will give you root. then get this off the playstore it cost a dollar but it will flash the boot.img from the rom you want to flash. use the app to flash the boot.img before you flash the rom then you can go into recovery and flash the zip
    Thanked by:
  25. Thread Author  Thread Author    #25
    Which rom and I might need help with all of this.
  1. Pre-ordered my phone... need help setting up
    By neoenigma in forum HTC One X
    Last Post: 05-04-2012, 01:35 PM
  2. Hoping I didnt brick my phone, NEED HELP!
    By Casutherland42 in forum AT&T Inspire 4G
    Last Post: 06-01-2011, 11:35 AM
  3. [RESOLVED] OMG Bricked my phone, need help!
    By deathbytampon in forum Verizon Fascinate Rooting, ROMs, and Hacks
    Last Post: 05-10-2011, 06:41 AM
  4. Can I use my phone as a wifi webcam for video chat?
    By whitenack in forum General Help and How To
    Last Post: 07-05-2010, 10:03 PM
  5. Sense = Force Close!!! Help, can't use my phone.
    By Ter1990 in forum HTC Droid Eris
    Last Post: 01-23-2010, 03:47 PM
