Results 1 to 5 of 5
    Arrow Updating Radio Problems :(
    So, I am new to the smartphone community rooting thing. I am not sure what the name is for the method of root i did, but i do have the link which is the following...
    I did everything as he said, and its been flawless, I had FreshLTE for a while until CM10 became a bit more stable. I proceeded to flash CM10 and its been a ball except for my signal, its been fuzzy.
    I searched a way to upgrade the Radio or "baseband" for that matter and most of the links lead to this one...there is even a youtube video
    I downloaded and flashed...which brings up the problem it does not flash instead it just says "Failed" :/
    I investigated and found out that I need S-off to do all this, and all roads lead to DityRacoon method. Which I follow the instructions, but when the RUU for the current Hboot comes up mine isn't and option. So now I am easily stuck and not sure what to do, or if it is even worth it.
    If there is an easy response please let me know, I prefer step by step guide (Bonus if video) just to keep it n00b friendly.
    Myphone info from bootloader:
    Jewel PVT Ship S-ON RL
    Hboot 1.12.0000
    Radio 1.02.12.0427
    Additional Info : I lost my Rooted Stock Backup File, so i litteraly only have FreshLTE backup and CM10 Backup
    I also noticed that with my FreshLTE i am able to pick up 4g vs my CM10 which won't, including signal strength
  2. #2
    benny3's Avatar
    Flashoholic!!
    Posts
    ROM
    Sense 5 Port
    Default Re: Updating Radio Problems :(
    What you need to do is go and download this RUU ,RUU_JEWEL_CL_ICS_40_Sprint_WWE_1.22.651.3_Radio_1.05.11.0606_NV_SPCS_2.45_003_release_268323_signed.exe it should be the second from the bottom
    This is a .exe so plug your phone phone in and double clck the file and it will do the rest
    What this will do is upgrade your firmware and the hboot to 1.15 so you can use the dirtyracoon for s-off
    If i Helped Please Hit The Thanks And Like Button
  3. #3
    baknblack's Avatar
    Posts
    Global Posts
    74 Global Posts
    ROM
    Stock rom netarchy kernel
    Think you also need to relock your bootloader to run the ruu
    MeanROM 4G LTE
    Phenomenal, ill get my hands dirty and i will let you know the results.
  5. #5
    baknblack's Avatar
    Posts
    Global Posts
    74 Global Posts
    ROM
    Quote Originally Posted by Elface Falso View Post
    Actually, when I did my wife's phone I ran the latest ruu so I got her the updated radios and 2.13 all at once. Phone was on the launch day 1.12 bootloader. All I had to do was relock. Didn't remove twrp or superuser. Ruu ran fine.
    MeanROM 4G LTE
  1. updating apps problem...
    By nneptune in forum Verizon Droid Incredible
    Last Post: 08-21-2010, 09:01 AM
  2. Skyraider with updated radio, slow download??
    By rcdeck in forum Incredible Rooting, ROMs, and Hacks
    Last Post: 08-19-2010, 11:29 AM
  3. updating radio
    By AllGood in forum Incredible Rooting, ROMs, and Hacks
    Last Post: 07-28-2010, 12:57 PM
  4. EVO FM Radio Problems
    By Redraider1 in forum HTC EVO 4G
    Last Post: 06-24-2010, 09:28 AM
  5. 2.1 update install problem
    By shcole in forum Samsung Moment
    Last Post: 05-16-2010, 02:09 PM
