Results 1 to 10 of 10
    ajbrad71's Avatar
    Posts
    Global Posts
    59 Global Posts
    Default Help
    I have downloaded all the files needed. Phone is unlocked and started using twrp recovery. When I go into fastboot usb it recognizes my phone but that's it. Can't go any further. Question, is all the downloads supposed to be in one spot. I've looked at several videos and they don't tell you what to do when fastboot won't recognize command.
    Sent from my EVO using Android Central Forums
  2. #2
    benny3's Avatar
    Flashoholic!!
    Posts
    ROM
    CleanROM SPR
    Default Re: Help
    Quote Originally Posted by ajbrad View Post
    Thats because the stock hboot doesnt support the extra fastboot commands. Do you have TWRP installed ?
    If i Helped Please Hit The Thanks And Like Button
    ajbrad71's Avatar
    Posts
    Global Posts
    59 Global Posts
    Default Re: Help
    Not on the phone, all I have is unlocked. So what method should I use? I have updated to jellybean.
  4. #4
    benny3's Avatar
    Flashoholic!!
    Posts
    ROM
    CleanROM SPR
    Default Re: Help
    Go here and download the bootloader version,rename it PJ75.IMG dont put the zip on the end. copy it to your external sdcard boot in to the bootloader and it will parse it and ask if you want to update, you do after its done reboot and remove the PJ75.IMG from your sdcard and you now have TWRP recovery installed
    ajbrad71's Avatar
    Posts
    Global Posts
    59 Global Posts
    Default Re: Help
    Did what you said. Watching the bootloader its saying no image. I tried with zip at the end and it said need to update when I hit bootloader.
  6. #6
    benny3's Avatar
    Flashoholic!!
    Posts
    ROM
    CleanROM SPR
    Default Re: Help
    it was a zip when you downloaded maybe you deleted the .zip when you renamed it ?
    if its asking to update tell it yes..thats what you want
    ajbrad71's Avatar
    Posts
    Global Posts
    59 Global Posts
    Default Re: Help
    Said yes, then it said update failed. File is old. By the way thanks for the help
  8. #8
    benny3's Avatar
    Flashoholic!!
    Posts
    ROM
    CleanROM SPR
    Default Re: Help
    Thats odd And you tried fastboot already?
  9. #9
    Default Re: Help
    I have noticed that everytime I shut down my phone or it shuts down because battery dies I loose all my pictures and Music Playlist created. Is their a reason why??? I have Droidlost install, angry birds, tetris ec. common games. Thanks
  10. #10
    benny3's Avatar
    Flashoholic!!
    Posts
    ROM
    CleanROM SPR
    Default Re: Help
    Quote Originally Posted by Emmanuel Colula View Post
    Not a clue sorry, I dont think it's very good idea to let your phone drain the battery dead very often
  1. HELP! Need to get G1 Working or Dieter Will Kill Me!
    By Rene Ritchie in forum The Android Central Lounge
    Last Post: 06-02-2013, 03:17 PM
  2. My Turn - Help Dieter with the G1
    By Dieter Bohn in forum The Android Central Lounge
    Last Post: 04-26-2013, 07:08 AM
  3. Round Robin: Help Jennifer with the G1!
    By gadgetgirl#ac in forum The Android Central Lounge
    Last Post: 12-14-2009, 08:59 PM
  4. SOS: All G1, Gmail, Gtalk contacts disappeared. Please help!
    By android007 in forum General Help and How To
    Last Post: 03-17-2009, 04:28 PM
  5. SOS: Please Help: IMport SMS from XML file to G1
    Last Post: 02-06-2009, 11:15 AM
