Results 1 to 6 of 6
- 01-24-2013, 09:48 AM
Thread Author #1
superSU problems
I rooted last night using RegawMOD, which went pretty well. That process installed superSU, but when I try to use Titanium Backup, it says the device isn't rooted. The SU app itself says it needs to update binaries, but each time, the installation fails. So far, I have tried a fresh install from the market, clearing data and preferences, etc. I've even downloaded the .zip from XDA, but when I reboot into TWRP, I can't seem to find the superSU file to flash from recovery. Anyone have any ideas for how to get this to work?
- 01-24-2013, 10:28 AM #2
- 01-24-2013, 09:45 PM
Thread Author #3
Re: superSU problems
Well, eventually TWRP was able to find the zip file. Unfortunately, flashing it didn't solve the problem. So I tried the second option, which was to flash Cyanogen10, which I planned to do anyway. The zip installed just fine, or so said the phone. But on reboot, all I could get to was the boot-up blue Cyanogen circle and the rom wouldn't boot even after 15 minutes of grinding at startup. Tried it twice.
So I have this rooted phone, except I can't run root apps on it or flash custom roms. Other than that.....
- 01-25-2013, 12:11 AM
Thread Author #4
Happy dance? Just for grins, I decided to try to flast MeanBean. And it worked! So I have a custom rom. And My Backup Pro asked for root access and got it, and is now restoring my apps and stuff. When that's done, I'll see if the other root apps work. Crossing my phalanges!
- 01-25-2013, 08:43 PM #5
Great! glad you got it. Any custom rom will have superuser and busybox baked in so as long as you stay with a custom or a stock rooted rom you should not have to worry about root.
When you flash a rom for the first time go to the superuser app and open it cuz sometimes it will come up with a box and say it needs to install the binary and if you dont it may act as if you dont have root. - 01-31-2013, 01:10 PM #6
I know what happened to me was that SuperSU needed to update its scripts. Make sure you open SuperSU to do this before expecting to grant anything root access.
MeanBean JUST updated SuperSU - MikyXDA does a great job with updates.
Text messaging problem with wifi on
By Anubis in forum HTC HeroReplies: 7Last Post: 10-23-2009, 04:18 PM -
problems with camera and battery
By piper09 in forum HTC HeroReplies: 10Last Post: 10-11-2009, 05:45 PM -
Sprint Hero has text messaging problem!
By maxfire05#ac in forum HTC HeroReplies: 10Last Post: 10-10-2009, 10:49 AM -
FreeRunner cupcake... teething problems
By Thorney in forum General Help and How ToReplies: 1Last Post: 09-05-2009, 12:41 AM -
problem with google sign in: password not valid
By sonali in forum T-Mobile G1Replies: 2Last Post: 06-20-2009, 10:39 AM
Reply
.jpg)
