Results 1 to 8 of 8
    Default scared please help might have no rom
    So got my evo 4g lte rooted the other day (first time new to the game). cool dude hooked
    Me up at a local mcdonalds, whatever. So everything was cool till I tried to install a rom
    Now the phone just stays on the htc logo. I can get to the teamwin screen and when I hit install
    All thats there is 2 folders with dots next to them and another that says TWRP before I messed
    With it there was all kinds of stuff on there. I did have titanium backup and did a system
    Back up before I tried to install a rom that I had no idea how to do. Tried to follow a youtube tutorial
    I dont think I downloaded the zip file correctly and when I went to install it it wasnt there so I think I
    Hit reboot and it wont go past the htc screen when powers up. Tell me I havent totaly screwed up
    My phone.
  2. #2
    benny3's Avatar
    Flashoholic!!
    Posts
    ROM
    Bad Boyz Rom
    Default Re: scared please help might have no rom
    Quote Originally Posted by new_to_the_root View Post
    My phone.
    Your fine... can you find the reboot options. if so reboot to recovery and you said you made a backup did you make one while in recovery?
    Any chance you have Gtalk on your pc? it will make this easier
    Quote Originally Posted by benny3 View Post
    Im not sure if i did it correctly but i did hit backup and it did what its suposse to do, i guess. I just right now in the team win recovery project hit reboot then recovery and the phone powered down then up again to the same team win recovery project. Im such a noob to this more help mr.benny please thank you.
  4. #4
    benny3's Avatar
    Flashoholic!!
    Posts
    ROM
    Bad Boyz Rom
    you should see Restore as one of the options in the menu tap it and it will bring up your backup, it should be a set of numbers like the date unless you named it, tap it
    There is no menu tap there are 8 choices install, backup, mount, advanced, wipe, restore
    Settings, and reboot when I tap restore it says select package to restore , but nothing
    Is there its empty. Thanks for taking the time to help me please stick with me I
    Need my phone.
  6. #6
    benny3's Avatar
    Flashoholic!!
    Posts
    ROM
    Bad Boyz Rom
    Did you make a backup while you were in recovery before you flashed the rom? What rom did you flash?
    And do you have Gtalk on your pc?
    Didnt even use a pc I think I flashed nothing
  8. #8
    benny3's Avatar
    Flashoholic!!
    Posts
    ROM
    Bad Boyz Rom
    I didnt ask if you used a pc i asked if you have Gtalk on your pc so we can use that instead of posting back and forth
    You need to tell me what you did from the start. I can not help you if you dont answer my questions. You said in the first post you installed a rom ...What rom?
  1. Help! I have no roms installed and am unable to install any.
    By unclefarkus in forum HTC EVO 4G LTE Rooting, ROMs, and Hacks
    Last Post: 01-27-2013, 07:15 PM
  2. Please help me install custom ROM...
    By blues runner in forum Epic 4G Touch Rooting, ROMs, and Hacks
    Last Post: 06-19-2012, 11:02 PM
  3. I might have bricked my phone with Rom Manager. Please help.
    By doughpe in forum LG Optimus S Rooting, ROMs, and Hacks
    Last Post: 06-29-2011, 09:59 PM
  4. Please help, rooted, flashed, no radio
    By Valquez9 in forum Thunderbolt Rooting, ROMs, and Hacks
    Last Post: 06-20-2011, 10:11 PM
  5. Replies: 2
    Last Post: 12-12-2010, 04:06 PM
B
