1. BlackHawkA4's Avatar
    Alright, I lost my backup. I need a rom that's just stock unrooted as is. I don't need all the fancy Ruu stuff and all that to go back to stock. I could only find a rooted rom. Anyone help me out? I can't find one for the life of me.
    05-17-2013 09:10 AM
  2. bosshaug12's Avatar
    Just use the RUU's unless you have a good reason not too. Its not fancy and pretty damn easy to use. Just make sure you pick the right one.
    AndroidFiles RUU
    05-17-2013 10:48 PM
  3. benny3's Avatar
    Why dont you want root ? Having superuser installed doesnt affect anything. Its still stock. If anything use 7zip and remove the superuser app. If you need i will do it for you just let me know
    05-18-2013 12:06 AM
  4. BlackHawkA4's Avatar
    The Rom I got was weird. Didn't have all the stock apps and everything installed. Superuser isn't even on here.
    The kernel is different. I want to update if there are any ota updates.
    Ruu didn't work for me for some reason. I was using ubutnu with rabies shot and I got up to the last step and it said Rom not comptable.
    05-18-2013 12:29 AM
  5. benny3's Avatar
    So your trying to go s-off?
    05-18-2013 12:51 AM
  6. BlackHawkA4's Avatar
    No. I just want to get back to oem. I'm sick of messing with it.
    05-18-2013 11:38 AM
  7. BlackHawkA4's Avatar
    O I see. The rabies shot is s off. Didn't work cause when I flashed the ruu didn't notice there was a failed 99 unknown error. Hmm.
    05-19-2013 12:08 PM
  8. cohoman's Avatar
    Did you see my posting here:
    Reverting back to Stock ROM before sending into HTC Trade-Up Program
    I was able to go back to unrooted stock ROM after following this procedure. Good luck!
    05-19-2013 12:29 PM
  9. BlackHawkA4's Avatar
    Yea, it's not working. Unknown error 99.
    05-19-2013 12:44 PM
  10. gollum18's Avatar
    Hmm if you download goomanager you can download the stock ruu file. It flashes back stock firmware.
    Open goomanager - > browse all files - > /ruu - > download latest JEWEL file as that is the evo LTE.
    Hook your phone up to pc, be sure to have HTC drivers installed. Transfer the ruu to your pc. Next open the ruu file and follow the directions.
    Sent from my SPH-L710 using Tapatalk 2
    05-19-2013 01:14 PM
  11. BlackHawkA4's Avatar
    I see what I did wrong. Skipped the oem lock step. L O L! Didn't think that would do anything. And then I had to flash it twice. Seems to be 100% stock now.
    Yup. Back to stock. And received and installed a ota. Very good.
    05-19-2013 01:21 PM
  12. benny3's Avatar
    That was my next question but i see you got it giong
    05-20-2013 06:16 AM
  13. BlackHawkA4's Avatar
    Yea. Woops. Lol.
    I'm use to the nexus way. And since I had a backup I always did it that way. Never did anything automated. Although the linux version of ruu isn't automated. Wasn't sure of this since everything else I saw was am exe for windows.
    05-20-2013 09:47 AM
  14. ffery's Avatar
    The easiest is way is to buy a new phone!
    Lol
    08-05-2013 12:48 AM
  1. help needed to update rom and kernel
    By wig77 in forum General Help and How To
    Last Post: 03-10-2013, 08:52 AM
  2. Help need to unroot!
    By kaivorth in forum Virgin Mobile Optimus V
    Last Post: 06-13-2012, 10:55 PM
  3. Stock, Unrooted Rom and Recovery for Optimus Q
    By michaelsj in forum Virgin Mobile Optimus Slider
    Last Post: 05-09-2012, 04:49 PM
  4. Help!!! need to unroot nook tablet
    By SadeLyn in forum Barnes & Noble Nook
    Last Post: 01-24-2012, 08:55 AM
  5. Help need stock splash screen without booting up android
    By blizz419 in forum Thunderbolt Rooting, ROMs, and Hacks
    Last Post: 09-01-2011, 08:03 PM
