1. KoukiFC3S's Avatar
    HTC EVO 4G LTE Shows Impressive Battery Life on Sprint's 3G Now Network
    The problem with this may be that hunting for a 4G signal when Sprints 4G LTE network isnt switched on yet may cause excessive battery drain, perhaps even more battery drain than if the phone is connected to a 4G tower. As such, in our test, we had turned off LTE connectivity in the phones setting and either operated the HTC EVO 4G LTE solely on Sprints 3G Now Network or connected to a WiFi hotspot and we found that our results fortunately contradicted battery results from other publications.
    Someone finally tested the battery life properly!
    4+ hours of screen on time with 25% battery remaining. I can live with that.
    05-15-2012 11:52 AM
  2. geomatrix's Avatar
    That's awesome, was it 4 hours consecutively?
    Sent from 3D, hope to be EVO LTE soon
    05-15-2012 12:15 PM
  3. KoukiFC3S's Avatar
    Looks like it was 4 hours over a 14 hour period.
    He even threw in some navigon GPS in there, and that's a big battery hog.
    Sent from my SPH-D710 using Tapatalk 2
    05-15-2012 12:18 PM
  4. ajonesma's Avatar
    looks like a pretty good battery then! It should be though since it's a 2000 mAh
    05-16-2012 10:29 PM
  5. vhira82's Avatar
    Hell yeah. Looking forward to it.
    05-16-2012 11:12 PM
  6. Shadowtc's Avatar
    Thats pretty good battery life compared to other phones
    Sent from my MB860 using Tapatalk 2
    05-16-2012 11:21 PM
  7. ajonesma's Avatar
    that little article has helped me make up my mind on which Sprint phone to get. I was having trouble deciding between the Galaxy Nexus and the EVO 4G LTE. Now I know its the EVO
    05-16-2012 11:27 PM
  8. Shadowtc's Avatar
    You should see gow long it last with juice defender installed
    05-16-2012 11:30 PM
  9. aztecgod106's Avatar
    Is that picture accurate? Why does the Android O.S. Bar have nothing? Wait I get it...that's stand-by hours right?
    Sent from my SPH-D710 using Android Central Forums
    05-16-2012 11:36 PM
  10. Shadowtc's Avatar
    Its maybe just cut in the corner
    05-17-2012 08:03 AM
  11. AdmiralAckbar89's Avatar
    I wonder what the screen brightness was set to? I'm inside all day so I keep mine arpind 20%. I imagine that could help squeeze a little bit more out of it (unless they were using a low screen brightness for the test).
    Sent from my PC36100 using Tapatalk 2
    05-17-2012 08:28 AM
  12. marrow's Avatar
    I believe I read on another site that this screen is cumulative. It is showing all the times it has been on battery, not just the current battery usage. As an example, the user in this picture may have had the phone on battery for 6 hours, then charged it, then on battery for 4 hours, then charged it, then on battery for another 4 hours. Basically it has been on battery a total of 14 hours over the life of the device.
    Hate to burst everyone's bubble.
    Marrow
    05-17-2012 09:46 AM
  13. illdini's Avatar
    If it's like the Evo 3D, that's the time since the phone was last unplugged from a charger.
    EDIT: I just checked, it is cumulative *sigh*. Still, I don't think the reviewer would be dishonest about the battery (hopefully).
    Sent from my PG86100 using Android Central Forums
    05-17-2012 09:53 AM
  14. marrow's Avatar
    It is probably not the reviewer being dishonest, but the reviewer not understanding or researching how the report ran. He probably had the phone on battery for 8-10 hours and just assumed that it was for the current length of time he had it on battery. We have seen plenty of reviewers do little to no research on the EVO LTE before their reviews were published, this does not suprise me.
    Marrow
    05-17-2012 10:21 AM
  15. KoukiFC3S's Avatar
    Marrow
    No the graph is correct. Check out the battery's curve. It's always declining, so he didn't plug it in.
    jbrown13 likes this.
    05-17-2012 10:52 AM
  16. Jackson Galaxy's Avatar
    I like curves
    05-17-2012 11:02 AM
  17. G3TCASHM0N3Y's Avatar
    Ah we got a thinker! Thanks for renewing my hope.
    Sent from my PC36100 using Android Central Forums
    05-17-2012 11:05 AM
  18. marrow's Avatar
    I think the time is cumulative, but the graph is for that particular battery session. My comments were around the point that he got 14+ hours on one charge (with 20%+ leftover). I hope the phone does this and that I am wrong, but I somehow doubt it is correct right out of the box (no new roms, no system update, etc).
    05-17-2012 11:06 AM
  19. KoukiFC3S's Avatar
    I sure hope not! Hopefully we can all find out ourselves next week.
    05-17-2012 11:17 AM
