Results 1 to 16 of 16
- 05-23-2012, 07:13 PM
Thread Author #1
Easiest way to backup current phone and transfer it to EVO LTE.
What does everyone think is the easiest way to do a transfer of all the information to the new EVO LTE?
I have the Samsung Epic Touch now and i cant wait to get my new phone up and rocking!
I think it will help if people give options for...
Is it rooted...
Is it stock....
Transfer from "manufacturer" to EVO LTE....
Sent from my SPH-D710 using Tapatalk 2 - 05-23-2012, 07:18 PM #2
Re: Easiest way to backup current phone and transfer it to EVO LT
im planning on making a backup via "mybackup" by rerware.
then eventually rooting and restoring said apps/data/etc to the phone.
it would be nice if sense/htc could manually do this via cloud, but i guess thats a little too much to ask. - 05-23-2012, 07:18 PM #3
- 05-23-2012, 07:21 PM #4
- 05-23-2012, 07:24 PM #5
- 05-23-2012, 07:26 PM #6
- 05-23-2012, 07:29 PM #7
I use Google for my contacts and calendar, so all of that is seamless. I don't mind re-installing apps one at a time. It'll give me a chance to get rid of ones I don't really use. Pictures, etc. are stored on the SD card so no problems there, though I'll probably make a backup on my PC and start fresh with those too.
- 05-23-2012, 07:32 PM #8
- 05-23-2012, 07:33 PM #9
- 05-23-2012, 07:40 PM #10
- 05-23-2012, 07:56 PM #11
- 05-23-2012, 08:44 PM #12
I'm not worried about contacts and calendar and stuff as Gmail already syncs those things automatically.
I'm worried about more important things like my progress on Angry Birds. I worked hard for all those stars and eggs!
I'm thinking TiBu apps from my old phone, root my EVO, install TiBu, then restore data as I reinstall apps.
If there's an easier or more efficient way I'd like to know.
Sent from my LS670 using Android Central Forums - 05-23-2012, 08:55 PM #13
Google makes the transfer easy for me. Contacts, calendar, Google drive, Google music.....I'm good, and I got my pictures on my SD card, so I will pop that in the new EVO and sync everything Google related.
Should've been sent from my HTC EVO 4G LTE using Android Central Forums. - 05-23-2012, 09:41 PM #14
I use MyBackup Pro it has saved me countless Hours doing full resets with the Evo do to Memory leakage.
- 05-23-2012, 09:50 PM #15
- 09-19-2012, 01:19 PM #16
Re: Easiest way to backup current phone and transfer it to EVO LTE.
my HTC EVO LTE doesn't have a SD card so I can not use the import/export function... when I do it says no SD card present.
How can I transfer the contacts to my computer? I tried just connecting it with a cable and searching for the contacts but I can not find all of them, only about half.
Reply
