Page 1 of 2 12 LastLast
Results 1 to 25 of 35
Like Tree1Likes
    Default How is the reception quality? (WIFI,3G, GPS, etc...)
    I've had the og EVO 4G and was pretty pleased with the reception and speedy GPS locks. I am now using the Epic 4G Touch and have noticed a significant increase in radio issues compared to my og EVO. ie: Total LOS, GPS never locking, constant roaming at work (where the EVO was solid at 1-2 Bars), weaker wifi signal, etc...
    Can anyone tell me if the new EVO 4G LTE holds true to having better radios than Samsung phones in general?
  2. #2
    RG129's Avatar
    Posts
    Global Posts
    178 Global Posts
    Default Re: How is the reception quality?
    Haven't really used the phone to talk to anybody, but I have noticed that the bars fluctuate more than my EVO3D. I don't know if that directly relates to dropped calls or not, I doubt it, because it never completely lost signal.
    However, my data speeds seem to be higher than with my old phone. (~1.1mb dl compared to ~.7mb dl on my 3D in my apartment).
    GPS locks super quick and accuracy in some apps show it's better than my 3D
  3. #3
    My GPS is faster and even more accurate to my very exact spot and when I tested my wifi with Speedtest I got higher than any other device I've ever tried (20 down, 8.5 up).
  4. #4
    i'm really curious about this as well.
    Anyone can post what phone they are coming from and if they find a noticible difference in the signal in what that got vs what this is getting?
    My OG EVO could always connect (albeit slow) when i was at my desk, but my Samsung Epic Touch sitting right at its side used to flounder and bomb out, try after try, test after test...
    Used to avg download speeds of 800+ kpbs with the EVO but under a 100kbps for ET4G, OG EVO would consistantly ping under 200, ET4G usually 900+....first i thought it was my imagination (went thru THREE ET4g's) but i'm convinced Samsung radios are inferior to HTC (at least to the OG EVO, but then again, back then, what phone WASN'T?!
    BTC
    Lost In LG Optimus G Pro Heaven, Lvg A Msg, Maybe I'll Call...(doubt it ) lol
  5. #5
    kbp08tls's Avatar
    Posts
    ROM
    Something AOSP
    Default
    So far so good with the E4GLTE. WiFi speeds are a little higher side by side compared with my old Optimus, and the couple of speed tests I've run on 3G are about 200k higher than before. Well see how that averages out over time. Haven't done much testing with GPS yet. The couple of times I've used it seemed quick and accurate.
    This mornings commute will be a good test. I ride a train that goes through some pretty flaky coverage areas that brought my old phone to its knees.
    Sent from my E4GLTE using Android Central Forums
  6. #6
    Default
    I haven't left the house since I got the phone so I've been using WiFi. I turned on the 3G this morning and attached my first two Speedtests. Not shabby. If I reactivate my OG EVO today I'll post a comparison.
    Husband commented on how much better the voice quality was. Call on my OG EVO sucked and I ended up using the speaker or Bluetooth.
    Sent from my EVO using Android Central Forums
    Attached Thumbnails Attached Thumbnails How is the reception quality? (WIFI,3G, GPS, etc...)-uploadfromtaptalk1337943810139.jpg
  7. #7
    I know for me I get a very speedy good gps lock
    and I have noticed that my evo is faster than
    most Motorola phone's. That I have in
    my house so I say it is. A very good
    phone well worth. The money
  8. Thread Author  Thread Author    #8
    Very good to hear positive reports of signal quality!
    I am considering the Evo LTE vs Galaxy S3 but was very concerned about samsung vs HTC's signal quality. Looks like I may actually pull the trigger on the EVO LTE.
    Any additional positive/negative reports on signal quality would be greatly appreciated.
  9. #9
    GPS seems to be vastly vastly improved from the GPS on the OG EVO
  10. #10
    race4life's Avatar
    Posts
    Global Posts
    21 Global Posts
    Default Re: How is the reception quality? (WIFI,3G, GPS, etc...)
    I am coming from a Galaxy II and I notice a drop in signal strength move to the EVOLTE. In spots before I would have 1 bar with the Galaxy but still make and receive calls. With the EVOLTE, I can't make or receive calls in those sames locations. I am going to see if it gets better, if not mine might be going back.
  11. #11
    Quote Originally Posted by bntran02 View Post
    Look at my sig, the samsung had horrible radios. The EVOLTE is just like out old school Evo 4G. Raidos are fine.
    -Bobby
    HTC Evo 4G, Samsung GSIIE4GT, The Samsung was a POS! Went back to the HTC Evo 4G, Now using the EVOLTE!
  12. #12
    kbp08tls's Avatar
    Posts
    ROM
    Something AOSP
    Well, I was able to stream Play Music without it pausing to buffer every couple of minutes for the first time ever this morning. Hopefully that's not an aberration. I did lose coverage in the same couple of places I've always lost it, but it seems there was enough music cached to get through - which means I was getting better bandwidth when I did have a signal. So, cautiously optimistic for now.
  13. #13
    race4life's Avatar
    Posts
    Global Posts
    21 Global Posts
    I wonder if there's something wrong with my EVO then. I had great sig with my Samsung but I'm not getting good sig now.
  14. #14
    losino's Avatar
    Posts
    Global Posts
    254 Global Posts
    Default
    I have come to the conclusion that Samsung phones all across the board seem to have reception issues. I am using a nexus s 4g and have weaker reception than I should
    Go Bucs!
  15. #15
    The 3G is terrible. Spotify cant play a song without cutting out every 10 seconds.
  16. #16
    i think i will have to exchange my EVO LTE because mine 3g/wifi cuts in and out. but i do love this phone and the GPS locks on really quick.
  17. #17
    Default
    Quote Originally Posted by kevster1321 View Post
    Yea I seem to be having the same issue.
    -Sent from my US Customs Edition EVO 4G LTE-
  18. #18
    Quote Originally Posted by RehniePants View Post
    Thanked by:
    RehniePants likes this.
  19. #19
    jnl813's Avatar
    Posts
    ROM
    Viper Rom ICS Android 4.0
    Coming from an Epic Touc 4G( GS2)...wow this thing blows that out of the water in signal anything!!! GPS literally locked in less than 5 seconds! Wifi was WAY stronger in the same room as my old phone... Man I've missed HTC!
  20. #20
    GPS, Radio and WIFI work excellent for me. Way better then my Epic Touch 4G. Super happy.
  21. #21
    Quote Originally Posted by DeputyDipshizz View Post
    im doing a factory reset hope that works will see.
  22. #22
    Quote Originally Posted by bobby35ny View Post
    -Bobby
    Here is another vote for crappy Samsung radios. The difference in 3G speeds and being able to hold a connection compared to my Epic 4G are very noticable
  23. #23
    I'm coming from a Nexus One on Tmobile. I was very displeased with my Tmobile. It wasn't very good when I lived in Bethlehem, PA. Since I moved to Savannah, GA it's been much worse.
    Everyone I know on Sprint is happy with the service so I expected a significant upgrade when I got my EVO. I'd say it's moderately better and I'm thinking of returning it. (I'm also rather unhappy with SenseUI.)
  24. #24
    From personal experience, Samsung has the worst radios. WIFI, GPS and 3g. Also on epic 4g, if i use navigation along with a car charger, it discharges faster than it charges. I don't have those issues with HTC. Anything that is not Samsung made is usually pretty cheap and low qality - plastic, radios, chargers. IMHO.
  25. #25
    My New Evo is SMOKING fast, especially compared to my ET4G , Samsung phones have horrible radios, I can only get around 100-500 kbps on my ET4G , my new evo is constantly getting 700 +
