Page 7 of 11 FirstFirst ... 45678910 ... LastLast
Results 151 to 175 of 254
Like Tree19Likes
  1. #151
    crxssi's Avatar
    Linux: The power beneath
    Posts
    Global Posts
    1,828 Global Posts
    Default Re: Battery Life
    Quote Originally Posted by Feech View Post
    I hate that I started this post. i'm depressed now. My battery is slightly better than my OG EVO. I don't know if I'm a power user or not but at about 1pm today my battery was approaching 40%. I went ahead and charged it up before I leave work but tomorrow I will not charge it until I go to bed to see what it is like. I'm assuming you guys are posting screens from the end of the day, but i would be curious what are you guys and gals seeing around 2pm in your day..
    At 8.5 hours today, I used 20% of the battery (battery at 80%), this was with taking several pictures, browsing a bit, a few text messages.... 30 min of screen "on" time. This is actually lower than typical for me, one day battery was at 90% after 9+hours on battery.
    Make absolutely sure you have "Best WiFi performance" option turned OFF.
    Besides that, your 3G signal level will eat at your battery, so can certain apps and such. If you think you are having a problem, I would recommend a factory reset, add your account back, and then leave everything STOCK (no apps, no changes of any settings) for at least a day and see what happens.
  2. #152
    Default
    Quote Originally Posted by MuzzFury5 View Post
    Sorry if I'm repeating anything here but I couldn't read through 6 pages of posts lol.
    I noticed that it is a bit better than the Evo 3D that I used to have but not by very much. At work I was usually around 30-40% left on my Evo 3D half way through the work day. Now with the 4G LTE I get about 50% half way through work (Which is 4 hours). And I hope we're going to be able to toggle LTE on/off like previous phones could with WiMax or else this phone won't last much with LTE turned on all the time. Also it seems to charge a bit slower than my old Evo 3D but I guess that' because it is a larger battery.
    If you're not going to read through I won't bother telling you how to turn LTE off... Pfftt..
  3. #153
    Incredibly impressed....3d, 17hr....
    Attached Thumbnails Attached Thumbnails Battery Life-screenshot_2012-06-08-01-13-56.png
  4. #154
    pteezay's Avatar
    Posts
    Global Posts
    285 Global Posts
    Default
    Quote Originally Posted by siradam134 View Post
    Did you even use your phone? Lol
    susanoo26 and ajonesma like this.
  5. #155
    I am really satisfied with this phones battery capabilities especially coming off of the OG EVO.
    It should be much higher now that I've finished messing around with it.
    LOVE THIS PHONE!
    Attached Thumbnails Attached Thumbnails Battery Life-screenshot_2012-06-08-09-08-43.jpg
  6. #156
    Default
    Admittedly light use but way better than the EVO3D.
    Sent from my EVO using Android Central Forums
    Attached Thumbnails Attached Thumbnails Battery Life-uploadfromtaptalk1339166645277.jpg
  7. #157
    Light use is fine. The OG Evo would drain to 80% just on my commute to work. My percentage now is 92% and its almost noon.
  8. #158
    Default
    Is it pitiful that I love the battery so much that I text daily screenshots of my battery life and usage to multiple friends constantly .... It's insane.Battery Life-uploadfromtaptalk1339176573725.jpg
    Sent from my EVO 4G LTE using Tapatalk 2
  9. #159
    susanoo26's Avatar
    Posts
    Global Posts
    83 Global Posts
    You guys must not be using your phone AT ALL to get 1day + of juice out of it! I got 10 hours out of mine with minimal use, auto screen brightness turned on with little phone time. When I do use it heavily I get 6 hours MAX. I love the EVO too, but come on. lol
    Thanked by:
  10. #160
    @susanoo26
    In some instances it may be that users are charging their phones, but not noticing that the battery history has not reset to 00.00.00.00.... For me, if it has not reset, then I restart the phone.
    With me, and with some light use - 5-10 text messages, 3-4 calls (Airave), 30 min of internet use, using wifi, hardly any 3G signal indoors, I get about 15-18 hrs out of the battery before charging.
    Thanked by:
  11. #161
    crxssi's Avatar
    Posts
    Global Posts
    1,828 Global Posts
    Quote Originally Posted by AppleR112 View Post
    That is only the "time on battery" statistics. The actually battery life, itself, is still accurate, regardless.
    Battery life is affected by so many things, even with light use. 3G signal level in stand-by is probably one factor that can severely affect runtime and varies greatly from location to location.
    I fear one reason it appears battery life is so wonderful for many people on standby is because the phone is dropping WiFi completely when asleep, even though it is not supposed to unless set that way... WiFi disconnects in sleep
  12. #162
    Default
    @susanoo26
    You're absolutely right, but you would see the graphics have an incline in it and not just declines.
    If I were to leave my phone untouched with very light usage I could easily get 48 hours... As it is now, I get between 18 and 20.
    In that case the picture would look like this one :
    Attached Thumbnails Attached Thumbnails Battery Life-uploadfromtaptalk1339188545557.jpg
  13. #163
    susanoo26's Avatar
    Posts
    Global Posts
    83 Global Posts
    Quote Originally Posted by Mikey47 View Post
    But within that 21 hours you must've plugged it in at some point right? This isn't directed at you as a shot, but I find it impossible that people are getting this type of battery output without charging it at some point. My battery life is more along reviews I've read where medium-heavy usage will get you about 5-7 hours.
  14. #164
    Quote Originally Posted by susanoo26 View Post
    Light usage I've gotten 50hrs. on a single full charge. I've gotten at least 13hrs on a single charge before I turned off full brightness. On some days I stream radio for several hrs. As long as I have it fully charged right before I go to bed, it will easily make it to next evening. My last charge lasted 1day 9hrs.
  15. #165
    npoz's Avatar
    Posts
    Global Posts
    22 Global Posts
    This thread reminds of the Seinfeld episode where Kramer tests drives the car and sees how far he can go on a tank of gas without refilling.
  16. #166
    Default
    First, if you look at that screen shot I provided, I did have it plugged in for a little bit there at the end. But, I've easily gotten 20 hours with medium usage (2-3 hours screen on time, streaming a couple hours of music some surfing, some testing, and a couple of phone calls.
    I have made it a "full day" (18 hours) ever since I've had this beast.
    Barring something wrong with your phone, either you usage pattern is a lot higher than mine or you have poor service compared to mine. Have you switched your network mode to CDMA only from CDMA/LTE?
    541rrhse likes this.
  17. #167
    liquidxit2's Avatar
    Posts
    Global Posts
    885 Global Posts
    ROM
    Stock ICS
    Default
    Yeah back to normal use and...
    Sent from my EVO using Tapatalk 2
  18. #168
    pteezay's Avatar
    Posts
    Global Posts
    285 Global Posts
    I'm with you bro. Either they don't use their phones or don't have any apps downloaded on it. Anything over 15hrs and I'm pleased. They must just let their phones just sit idle because if you look at their screenshots hardly anything is running. I didn't buy this thing to just let it sit around, I bought this things to utilize every feature possible: apps, music, movies, camera, email, texts, calls, etc. and I'm getting just over 15hrs on about 3-4 bars of signal strength and 50/50 between 3g and wifi.
    Thanked by:
  19. #169
    So are you suggesting others should match your use case?
    Peoplea re simply posting whta their battery life is like...i'm similar, i get easily 12-18 hours. And this is with heavy screen on time from tapatalk since i basically use the phone like a tablet when i'm home.
    Compare that to the OG evo or hell my windows phone i came from and its exactly all i need from a phone.
    If you play any intensive 3D games ALL phones will take a battery hit. The key here is stand by battery is one of the best out of any android devices imo and for normal use I find it very good in my use cases.
    I don't know how others use the phone, but i guess thats not my problem them.
    ::kanye shrug::
  20. #170
    Hell here you go....I actually unplugged my phone right around 8:30am....i did a restart in the middle of the day because of the disappearing Chrome icon after the update so don't pay attention to time on battery as its incorrect.
    So this is 8:30am to 1:05am: 17 and 1/2 hours.
  21. #171
    If you are only getting 10 hours on minimal use you either don't have good service or your phone is busted.
    my minimal use is on pace for 24 hours most of the time.
  22. #172
    Default
    Here is what I got
    Attached Thumbnails Attached Thumbnails Battery Life-uploadfromtaptalk1339246089905.jpg
  23. #173
    crxssi's Avatar
    Posts
    Global Posts
    1,828 Global Posts
    Quote Originally Posted by DougB541 View Post
    Or has a bad app that is not doing what it should.
    Or turned on "Best Wi-Fi performance" (a big no-no).
    Or messed with some other settings.
  24. #174
    It's obvious that battery usage is all relative and the big thing here is that the people who are in disbelief are comparing their usage to other's usage ... If you commute by public transit and listen to music/stream videos or play games for hours, then text/talk/email etc then of course your battery life will be different ... 1) Compare usage to usage. Meaning compare your own usage now to the usage you had on your previous device ... It has got to be at least twice as good. Some of these people are claiming to ONLY get 10-12 hours on heavy use, but arent saying they were only getting 5 hours on their previous device with the same usage. 2) For the disbelievers, show us your usage ... Let us see how your using your device that isn't getting good enough battery life for you.
    Hit the THANKS in appreciation if I or anyone else has helped you in any way .. A Strong Android Community
    http://mydamnbrainhurts.wordpress.com/
    http://twitter.com/mydamnbrainhurt
  25. #175
    You guys must not be using your phone AT ALL to get 1day + of juice out of it! I got 10 hours out of mine with minimal use, auto screen brightness turned on with little phone time. When I do use it heavily I get 6 hours MAX. I love the EVO too, but come on. lol.
    I don't know what your definition of minimal use is (show us a screenshot), but if your definition is the same as mine and you didn't get at least a full 24hrs of battery life your phone or setup is SERIOUSLY BUSTED.
