Page 3 of 3 FirstFirst 123
Results 51 to 57 of 57
Like Tree5Likes
  1. #51
    Hitechrv's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: So... foxfi works on the Evo
    I was able to install it on my original 4g Evo by installing Firefox, then using Firefox to go to FoxFi Installer and download version 1.91.3 then install it. I am getting the error about htc hotspot lock not letting wifi mode activate. Am I doing something wrong? I am on Sprint.
  2. #52
    adventure95004's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Hitechrv View Post
    I was having trouble with my evolte after update, the link you had worked to update FoxFi it works fine including the password function
    Sent from my EVO using Tapatalk 2
  3. #53
    cuffs50's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    It works fine for my lte but won't work on the wife's og evo. Gives the blocked by sprint thing and says you can use the bluetooth feature only. Never tried it so not sure if it works.
    Sent from my EVO using Android Central Forums
  4. #54
    axllebeer's Avatar
    Posts
    Global Posts
    2,735 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Everything working fine here after the most recent update and before on my Evo LTE
  5. #55
    Zookeeper63's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock-unrooted
    installed Foxfi after the update on my new LTEvo, it works for a while, then it stops transmitting and I get an error message saying a task manager or battery conservation app is shutting down the wifi I've turned off the task manager and still get random shut downs. Any ideas?
  6. #56
    djrez's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The same thing is happening to me. I have the full version and it shuts down after a while with a notice about the battery conservation or a task manager may have shut wifi off. The only thing I can do is completely restart my phone. It's very annoying, did anyone find a solution for this? I also have an HTC EVO LTE.
  7. #57
    crxssi's Avatar
    Linux: The power beneath
    Posts
    Global Posts
    2,990 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by djrez View Post
    This is essentially a dead thread. FoxFi is broken in Jellybean. It won't work for a "while", it won't work for a "short time" either. There is no news if there will ever be a fix.
    http://forums.androidcentral.com/htc...elly-bean.html
