DEAL OF THE DAY: Save 28% on the Seidio OBEX Waterproof Combo for Samsung Galaxy S3!
Results 1 to 4 of 4
    justryan's Avatar
    Posts
    Global Posts
    33 Global Posts
    Default Format SD card on EVO LTE?
    Trying to format my SD card from my OG EVO and having some issues. When I go into Settings>Storage the function "Erase storage card" is grayed out. I cannot select it. I don't see any other option to format this card. Anyone else have this issue? Did you find a solution?
  2. #2
    rjl2's Avatar
    Posts
    Global Posts
    63 Global Posts
    Default Re: Format SD card on EVO LTE?
    You have to unmount it before the erase option is available.
    justryan's Avatar
    Posts
    Global Posts
    33 Global Posts
    Thank you. That worked!
  4. #4
    Default
    What 32 gb micro sd card should I get for the EVO LTE?
