Page 2 of 2 FirstFirst 12
Results 26 to 33 of 33
  1. #26
    fredster309's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Fix for the Weather "Current Location" bug
    You need to update google play to 4.1.10
    com.android.vending-4.1.10.apk
  2. #27
    Emmanuel11's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm having the same problem :-(
    Attached Thumbnails Attached Thumbnails Fix for the Weather "Current Location" bug-uploadfromtaptalk1370323935563.jpg
  3. #28
    groovepeppy's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Already install the 4.1.10, i even wipe cache and dalvik, problem still persist.
  4. #29
    snewbs's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    When the phone sticks on a wrong current location it seems to be related to the "Location service". This should be an app you have installed like a map app. You can reinstall and reset the Location service by selecting the last option in the Weather menu.
    Best to do this when connected to wifi to save costs.
    If you have turned off the location settings in the main menu , the weather app will prompt you to turn them on again.
    Once reinstalled / reset the current location should update. You will need to refresh weather to then get the latest details at the new current location.
    Cheers!
  5. #30
    kc2fya's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I found by conducting a Sync to the Weather and HTC Sense (3.6) resolves this issue. I have my "Auto-Sync" turned off, so once in a while I have to manually sync the two I mentioned. I hope this helps you out.
  6. #31
    Roger Norvell's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Look At Post #23 by Wab1975 settings, Power, Fast Boot Off *
    Thank you very much, your tip fixed it instantly. When I upgraded to ICS and setup the sync the first time that's when my city in Va was replaced with the buggy "Current Location" but I liked having each city show up in the widget. The upgrade to ICS puts that fast boot on. Now the phone boots slow like with the older ver of android and sense. I'll take slow boot and have things work correctly.
    Thanks now I can stop searching endlessly.
  7. #32
    Wealthresource's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by wab1975 View Post
    I have been having the same problem with my HTC One X Plus recently. The HTC weather app shows "Current Location" regardless of syncing the app etc. I found that by updating Settings>>Power and unticking "Fast Boot" then powering off (not restarting) and switching back on resolved my issue!
    Thanks ... this worked for me!
  8. #33
    jon72's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Went into weather app, tapped on location sources, used the high frequency radio button. Message flashes up about Google sharing location information. Said no previously but decided to say yes cos nothing else worked. Unsatisfactory but it works now.
