04-04-2014 09:57 PM
137 ... 3456
tools
  1. brokenchode's Avatar
    I am also having an issue with repeatably hitting the back button. In addition I am seeing that my touches don't always register, takes a couple tries sometimes...
    Anyone else having this issue?
    I am unsuccessful at getting a sure fire replication, so leaving it with the tech guys might not work.
    Usually I can replicate by touching the home screen, not on an app, then trying a shortcut. Won't register...
    Also by swiping down at the top almost always takes a couple tries.
    3days with the phone thus far, love it compared to evo 3d....
    07-24-2012 10:39 PM
  2. pjrake's Avatar
    I can't seem to set google chrome as my default browser. I clear the defaults for both but it doesn't ask me which I want to use to complete the action, it just uses the stock browser
    Sent from my EVO using Android Central Forums
    Go to Settings, App Associations and choose Web urls and select chrome.
    Sent from my EVO using Tapatalk 2
    07-25-2012 07:13 AM
  3. OGEVO4G_LTE's Avatar
    I'm having issues with the notification bar not sliding in portrait and only works in landscape. I've read it might be due to the ottercase but when I remove the case the issue remains. Also I've did a factory reset thinking it was my ROM but nope. After doing some investigation, I took a very thin piece of paper and wipe in between the seams right above the HTC logo. Guess what - that work temporarily for a week until the issue came back again. I repeated the same steps to correct it the first time and it worked again. So I believe something is getting disconnected between there.
    07-26-2012 03:33 PM
  4. zmann's Avatar
    Anybody having issue with losing 3g for a minute here and there i did something that has stopped mine from doing it,,, I went into settings and shut my lte radio off. I do not have lte yet anyway so I just turned it off and I have not lost 3g from time to time anymore. It's been 3 whole days.
    Sent from my EVO 4g lte
    07-29-2012 06:31 AM
  5. DisplacedMic's Avatar
    Ever since the OTA i can't get the gmail, play store or Maps apps to work properly.
    gmail freezes at a white screen, the app store freezes when i try and select gmail to leave a 1 star rating and inform the developers.
    driving me nuts. tried clearing chache, reboots, reinstalls everything i can think of.
    07-29-2012 09:08 AM
  6. JAYE820's Avatar
    When in pull down my notification bar it's always empty for some reason. This happens %70 of the time.
    07-29-2012 09:29 AM
  7. Magman007's Avatar
    There is a turn off WiFi when not connected setting.
    Click to view quoted image
    from Evo4GLTE on Android Central
    how do you get to this screen? I cannot find it!
    07-30-2012 05:03 PM
  8. Mercury81's Avatar
    Wii fi on, upper right corner three dot menu,Advanced,
    sent from Evo4GLTE on AC forums
    07-30-2012 06:04 PM
  9. mobilesat69's Avatar
    anyone else having a problem with their camera? Everytime I start the camera app it goes right to my front camera and there is no option in camera settings to change it to the rear camera. Any help would be greatly appreciated.
    07-30-2012 09:06 PM
  10. Mercury81's Avatar
    Yes the camera setting is in there, setting camera at top front/ main select main.
    07-30-2012 09:30 PM
  11. kdub1969's Avatar
    I've had my HTC EVO 4G LTE is less than 2 weeks and I've already taken it into sprint because when on 3G network phone will not connect with anything i.e. Google Play, Spotify, Internet, you name it!
    The tech performed a data reset and changed my network connection from LTE/CDMA to CDMA only and told me to leave it on that setting for several days. WHY would I do that?!? I bought the phone for the LTE capability. I'm REALLY confused as to what or who I should be pissed at. Believe me, I"M NOT A HAPPY CAMPER AT THE MOMENT!
    I have never been able to use Youtube since I've had the phone...."connection lost please tap to retry" error message is the only good thing the youtube app is good for.
    Call me crazy but I expected this phone to be an improvement over my last phone, the original HTC EVO 4G. If anything it's twice as bad, at least I could use the data connection with it.
    Could someone help me out and please tell me where my hatred should be directed?
    08-04-2012 07:22 PM
  12. AlternetConcept's Avatar
    Need to have LTE in your area in order to use the 4G capabilities.. Do you know if your area has it?
    Trust me I'm having a few issues myself and I'm completely regretting upgrading for another 2 years.. If I could I'd go back in a heart beat and leave sprint altogether.. Their service in my area is just not good enough to justify having such a high end phone..
    kdub1969 likes this.
    08-04-2012 07:30 PM
  13. zmann's Avatar
    I have had my evo for a week now and the first few days I would lose 3g connection here and there. I do not have lte yet in my area and what I figured out was with the lte on it would search for a lte signal all the time and that is why I would lose 3g sometime. I turned lte off and I have not lost my 3g once since. It's stupid to keep lte on if you don't have lte service yet. If you have lte service and your phone is acting like this then obviously this would not apply to you.
    08-04-2012 07:38 PM
  14. kdub1969's Avatar
    Yes, I'm in Dallas/Ft. Worth
    08-04-2012 08:22 PM
  15. kdub1969's Avatar
    Yes, I live in Dallas Ft. Worth
    08-04-2012 08:24 PM
  16. AlternetConcept's Avatar
    That's odd.. I would leave it on CDMA only for a day or so .. see how it performs.. then switch back to CDMA/LTE and see if it's worse... I can't really tell ya much since I don't have LTE yet in my area so I couldn't tell ya if this happened to me..
    08-04-2012 09:13 PM
  17. emanuelm123's Avatar
    I too when I first got the phone noticed it would go in and out of 3g and sometimes would not connect and it seemed to only do it in certain areas, it only worked if I went in and out of airplane mode but I figured it had something to do with network vision and all the updates and so I waited a couple weeks and now the problem is no more, I am in Arlington (dfw area) and still get no 4g service only in one place I've noticed but is non existent anywhere else here in Arlington (well to my knowledge)
    Sent from my Evo 4g lte on Android Central Forums
    08-04-2012 09:18 PM
  18. p1eric's Avatar
    I'm having the same issue I think. Maps, gmail and the stock browser all freeze with a white screen at least once a day. I've tried killing the app, clearing cache, killing sense, etc. The only thing that fixes it is a reboot. I guess I'll try a factory reset and see if that helps.
    08-05-2012 08:15 AM
  19. kiwicarlos741's Avatar
    For the person who bought the phone for LTE capability, if u don't have LTE coverage in your area then u should have done your homework before buying the phone and complaining
    08-06-2012 12:11 AM
  20. cuffs50's Avatar
    I have network problems. One minute its working fine then no data for bout 10/15 minutes then just starts working again. Tried shutdown and restarts nothing will reconnect to data on its own. But calls and text work fine while thus is happening.
    I have the same issue. Calls and txts will always work without data but no internet or multimedia.
    08-06-2012 08:38 AM
  21. cuffs50's Avatar
    Well in defense of that no one had LTE until very recently and I think its pretty poor planning on sprints part to release an LTE phone with absolutely no network to support it.
    08-06-2012 08:41 AM
  22. MrPassion's Avatar
    So, you would rather have a phone that would not work on LTE when it comes to your area?
    08-06-2012 12:14 PM
  23. kiwicarlos741's Avatar
    Before this phone cane out, sprint had where all the LTE markets would be starting to roll out so like I said, ppl should do there homework before buying something without knowing what thwyre getting
    08-06-2012 09:37 PM
  24. Txchas's Avatar
    Not to mention that sprint continues to show city maps with full coverage LTE when it is anything but.
    08-06-2012 09:50 PM
  25. 247TEK's Avatar
    Only issues I have with this phone is that Pandora won't play. The app came up and music was there but it didn't play. Found a link on the net and downgraded it. Now it works perfect.
    08-06-2012 11:51 PM
137 ... 3456
