11-11-2012 03:48 PM
32 12
tools
  1. dave12285's Avatar
    I understand that you need the special dongle to get the better bit rate and all that good stuff.
    What i'm getting at is that the bluetooth audio is awesome with stock android even with a2dp and factory bluetooth in your car. I'd be willing to bet that my og evo without sense sounds beautiful compared to the new evo in my car. There's no reason why they shouldn't increase the bitpool settings to make the audio sound good from the factory. Now we have to buy a $60 dongle when it already has the capability to sound awesome. Kind of lame in my opinion. If you search for "bluetooth bitpool android" you'll see plenty of threads on different forums of people trying to solve the issue. It hasn't been solved to date other than switching to a non sense rom.
    06-09-2012 06:48 PM
  2. chesalaam's Avatar
    maybe I just dont realize how good it should sound, but the music from phone going thru Bluetooth to my car sounds phenomenal!!!! I bought a new stereo bcuz the stock one didn't have the ability to stream via bt, but this new one uses a2dp and still sounds unbelievable to me and my wife.
    06-09-2012 07:38 PM
  3. dave12285's Avatar
    Well if it sounds unbelievable maybe I'm wrong about it. Or you have a head unit with the new bluetooth protocol that has the higher bitrate as discussed before.
    Sent from my PC36100 using Android Central Forums
    06-10-2012 10:06 AM
  4. chesalaam's Avatar
    as mentioned, the headset I bought has a2dp according to the spec sheet. is the bitrate and a2dp something different? perhaps I'm looking at the wrong thing
    06-10-2012 02:13 PM
  5. miicho85's Avatar
    BT sounds way better in my car than when using Aux
    06-11-2012 12:59 AM
  6. dave12285's Avatar
    No, it's just that the new standard, aptX, has a higher bitrate.
    06-12-2012 10:48 AM
  7. originofpeace's Avatar
    For my phone it seems to be connected but when I plug it into my ford focus audio jack, no sound comes out. That's a total disappointment
    11-11-2012 03:48 PM
32 12
