DEAL OF THE DAY: Save 37% on the Seidio SURFACE Case for Samsung Galaxy S4!
Results 1 to 9 of 9
Like Tree5Likes
  • 3 Post By corvette72778
  • 2 Post By crxssi
    Default Hidden Feature in EVO LTE? Power Saver
    I found a "hidden feature" by using the shortcut maker app. Its the old power saver setting that the updated EVO 3D had. Maybe I just can't find it but when I was making a short cut for the removed call history shortcut (don't understand why that was removed), I also found power saver with all the settings to help battery life. I really liked this feature and wondered why they removed it. As it turns out, its not removed its just "hidden". It looks by default, all the settings other than animations are on power save.
    I think I went through all of the actions but post any other cool shortcut maker functions you find. I was looking for a shortcut to toggle NFC on and off rather then going through all the settings its buried in but I didn't notice it.
    Thanked by 5:
    crxssi, Wiley_11 and kaablewy like this.
  2. #2
    Default Re: Hidden Feature in EVO LTE? Power Saver
    Wondering - when do these power saver settings apply? When battery is depleted? After x number of minutes or hours?
  3. #3
    crxssi's Avatar
    Linux: The power beneath
    Posts
    Global Posts
    1,823 Global Posts
    Wow! This is a *GREAT* find! This could truly be the solution to several issues I have been having with the phone. What he used was "QuickShortcutMaker" ( ) from the market. Open that program, then search for "power", and you will see several choices. The first one is labeled:
    "Settings
    Power saver settings"
    Create an icon for it and launch it. What you will then seen is in the screenshot I supplied, below. So many things to try now.
    Attached Thumbnails Attached Thumbnails Hidden Feature in EVO LTE? Power Saver-2012-06-16_16-57-25.jpg
    Click "Thanks" and/or "Like" button on posts where someone helped you or you liked the posting. Provide HTC feedback here: http://www.htc.com/www/contact/email
    Thanked by 6:
    pteezay and kaablewy like this.
  4. #4
    crxssi's Avatar
    Posts
    Global Posts
    1,823 Global Posts
    Quote Originally Posted by bc2k View Post
    Good question. No answer right now. HTC is not known for useful documentation....
  5. #5
    rjl2's Avatar
    Posts
    Global Posts
    63 Global Posts
    Great find. I'm hoping this works.
  6. #6
    I downloaded this to my Sprint Evo LTE and went looking for a quicker GPS on/off toggle, instead of being routed to the GPS menu each time.
    I opened the quick shortcut app and searched "Location" and three settings results came up. The third one down, with "HtcCdmaGPSLocationSettingV2" directs me to a Verizon Wireless Location services toggle. The standalone checkbox still toggles my GPS on and off from this page, but I thought this was interesting. Is this a relic from previous iterations or a sign of things to come from Verizon?
    Also, can anyone confirm that the secret power saving menu that this app leads to has any effect on this phone? I have tried a few of them, like screen timeout to 30 seconds (doesn't timeout after 30 seconds) and disable animations (doesn't disable animations)...so is this menu actually toggling anything?
  7. #7
    cmandd's Avatar
    Posts
    Global Posts
    128 Global Posts
    Like on the Rezound's ICS, these settings take effect at 20% battery.
  8. #8
    p2cactus's Avatar
    Posts
    ROM
    CM7
    Default
    Quote Originally Posted by cmandd View Post
    Some evidence? I did a little experimenting today, and I couldn't tell that they did anything.
    EVOLTE and AC FTW!
  9. #9
    crxssi's Avatar
    Posts
    Global Posts
    1,823 Global Posts
    Quote Originally Posted by p2cactus View Post
    Well, if you believe him, then unless your battery went below 20%, none of the features were activated, so they WOULD do nothing otherwise. Right now, I don't know what to believe. It would be nice if this stuff was documented somewhere. My tests are going to take a long time- two of them were ruined today.
