Results 1 to 16 of 16
Like Tree4Likes
  • 1 Post By flyer8493
  • 1 Post By htc evo 4g
  • 2 Post By crzycrkr
    Default Screen is constantly using 63% battery ?!?!
    I has gotten this replacement EVO the other day. So far everything is smooth but I notice one thing that is constant. The screen battery usage is on average at 63%. Even after I left the phone off for a couple of minutes, immediately when I wake up, I snap a screenshot and even after I reboot the phone, it starts low then gradually jumps up to about 63%. I even disabled auto brightness and moved it down to about the lowest I could set it to while still being able to see the screen. If I use it for awhile it would go higher than 63%. I'm thinking that if this wasn't an issue, I know ny battery would be much much better. Is my second EVO another defective one? I hope not!. Attached is the latest screenshot.
    Sent from my EVO using Android Central Forums
    Attached Thumbnails Attached Thumbnails Screen is constantly using 63% battery ?!?!-uploadfromtaptalk1340227309009.jpg
  2. #2
    Default Re: Screen is constantly using 63% battery ?!?!
    It says, that of the amount of battery that has been used so far... 63% of that went ot the screen.
    It does not say that your batter has been used up 63% due to the screen.
  3. #3
    flyer8493's Avatar
    Posts
    ROM
    CM7 or a stock sense rom
    Default
    When will people learn to just enjoy the phone instead of trying to find something wrong with it?
    Thanked by 4:
    chud likes this.
    Quote Originally Posted by Ciege View Post
    On my old evo i noticed that if the phone is off for quite sometime and i turn it on and check battery, i notice that it would start out at around 35% then it would gradually increase. On this new on, no matter how long its been off, it shows 63% right off the bat. Never will it decrease unless after a reboot. So this is normal?
  5. #5
    crxssi's Avatar
    Linux: The power beneath
    Posts
    Global Posts
    1,826 Global Posts
    Quote Originally Posted by htc evo 4g View Post
    It should reset after a full charge.
    Yes, it is pretty normal for the screen to show around the numbers you say. Turning it "off" for a few minutes or even an hour is not likely to change the number much, since it is a total usage percent since the last charge.
    Click "Thanks" and/or "Like" button on posts where someone helped you or you liked the posting. Provide HTC feedback here: http://www.htc.com/www/contact/email
    Thanked by:
    Quote Originally Posted by crxssi View Post
    THANKS for the input. Well in that case, one reason why i exchanged to this new evo is because of the battery life. On this new EVO, the battery level remains the same as the old one! And with the old one, i could never ever achieve 18+ hours (my max was about 16hours). Am i not configuring something right here? I use live wallpapers and i know that uses a little bit of battery but still, i cant achieve that long battery life. Any suggestions, tips, etc?
    thanks
  7. #7
    crxssi's Avatar
    Posts
    Global Posts
    1,826 Global Posts
    There are millions of threads on here to address that. Here are a few common/well known/easy tips:
    * Make sure you NEVER turn on "Best WiFi Performance"
    * Do not load apps that constantly trigger data events
    * Do not use live wallpapers
    * Use WiFi whenever possible
    * Turn your screen brightness down
    * If you like music, then load several hundred hours on your SD card, don't stream
    If you have a very weak 3G signal, it can and will drain your battery much faster. Not much you can do about that, though. Battery life will improve GREATLY after several charging cycles.
  8. Thread Author  Thread Author    #8
    I NEVER use "best wifi performance"
    I use mainly espn, flixster, calendar, clock w/weather update as my data searching apps on my home page.
    I always use WiFi
    I had screen brightness mostly all the way down but changed it back to auto brightness b/c i didnt see any major change.
    Havent loaded/streamed any music on this new device.
    I really really hope battery life will improve greatly after several charge cycles.
    Thanks!
  9. #9
    getitoutme2's Avatar
    Posts
    ROM
    MeanROM ICS v1.1
    I have never seen my screen account for less than 50% of the battery usage since have a screen 4" or larger.
  10. Thread Author  Thread Author    #10
    OK. my phone has been fully charged for a couple of minutes and i left it in the charger for a couple more minutes before i pulled the plug out. Right when i pulled the plug out i went and looked at the battery screen and i see that the screen is in the 90% range and is constant at 79%. My question is since the screen is used mostly 100% of the time, how or what will cause the screen battery to jump down to lower battery usage?
  11. #11
    crxssi's Avatar
    Posts
    Global Posts
    1,826 Global Posts
    Mostly just LONG periods of time of non-use, or by using applications that actually use the CPU or download data. That will start to change the balance. For example- launch an intense action game and play that for 10 minutes and watch what happens.
  12. Thread Author  Thread Author    #12
    If you look at the battery life post and you see the pics of the screenshots of people that posted their battery life, youll notice that most of them the screen battery is on the low end..like 29-40% around there. And i do notice that there are some screens that are around my range.
    take a look for yourself.
    Battery Life
    crxssi likes this.
  13. #13
    crzycrkr's Avatar
    Posts
    Global Posts
    1,524 Global Posts
    ROM
    AOKP35/Matr1x19.5
    Default
    I seriously think they need to explain percentages better in school
    Sent from my EVO LTE using Tapatalk 2
    chud and kaablewy like this.
  14. #14
    bgesullo's Avatar
    Posts
    Global Posts
    175 Global Posts
    I have had my Evo 4G lTE since launch day and my battery last me a good 8 hours and I make a bunch of phone calls and have my exchange server email for work on. I have noticed the screen takes some power but that's only if I have the brightness turned up.
  15. #15
    Default
    Allow me to explain OP. The percent that your phone displays is the percent of what the battery us putting its energy towards powering. If it is a high percrnt, it just simply means that your screen might be the only thing your battery is powrring. Hopefully I cleared some things for you.
    Thanked by:
  16. #16
    The percentage shown in the power setting is a percentage of battery used.
    Let's say the remaining battery is 70% and total screen utilization is 63% then the battery utilization by the screen is 0.63x(100-70)= 18.9%
    Check the total amount of time the screen was on and it will give you a rough idea of how much longer your phone will last.
    On my phone screen is consistently the highest as I usually browse on the phone. Playing games will drain battery faster and being in a location with spotty coverage will drain battery even faster. To combat the 3G coverage issue I usually use "roam control "and just switch to roam ony mode.
    Thanked by 2:
