Results 1 to 8 of 8
- 06-20-2012, 10:06 PM
Thread Author #1
I need help!
I've never returned a phone. I dont know what checks they do to the phone to ensure it isnt tampered with. My phone is rooted and as of now my screen doesnt work (it's on but it is near impossible to see because it's super dim). I cant unroot it because my phone is stuck in a loop after i tryied to factory reset it. My real question is can they check if my phone is rooted even though they cant access my phone. I bet they can, but do they check for it?
Also, if anyone knows how to restore a phone to stock setting (the RUU i'm guessing) without accessing the phone itself please help me.
Thanks guys - 06-20-2012, 10:20 PM #2
Re: I need help!
If you take your phone in and they see its in a constant boot loop im pretty sure the store employees arent going to do anything but the bare minimum and walk to the back and hand you a new phone.
- 06-20-2012, 10:25 PM #3
Re: I need help!
I would visit a Sprint corporate store and ask them to re-flash you image because it is stuck in a boot loop. My experience is that the techs that service them in the store do not care and probably do not look. They will just hook it up to their recovery notebook and push the image to your phone.
I had to have my last phone re-flashed about five times, so I got the routine down a bit. And each time it was rooted (and a little ugly fwiw).
Make a reservation online with a nearby corporate Sprint store for technical assistance, that way they will probably work on it while you are there, around 15-20 minutes. Otherwise you have to leave it and pick it up later.
Best of luck
sabbys - 06-20-2012, 10:26 PM
Thread Author #4
Re: I need help!
Alright, as long as the employees are pretty lax. besides you cant SEE the screen anyway, the phone is pitch black (the only place it's readable in is my kitchen under direct lighting).
I just dont want them to find out it's rooted. Push come to shove i'll just take a hammer to the phone... - 06-20-2012, 10:31 PM
Thread Author #5
Re: I need help!
The bootloop isnt the problem, its the screen. I cant see anything. Fixing a boot isnt hard i just cant see what im doing.
- 06-20-2012, 10:31 PM #6
Re: I need help!
Boot into bootloader, flash RUU. If that doesnt fix it, go exchange it. Yes they can certainly tell if it is rooted, and have even charged people for the new phone in the past once it got to a service center and THEY found out it was rooted. But that is rare, normally they do not check. You voided your warranty rooting it, and if necessary, should be prepared to live without a warranty and pay the consequences (not saying you rooting it had anything to do with the defect).
- 06-20-2012, 10:34 PM #7
- 06-20-2012, 10:39 PM #8
Good luck the last time I walked into a sprint store with a rooted phone they acted like it was going to bite them
sent from a EVO that survived a Apple attack... thug life
Reply
