Page 1 of 2 12 LastLast
Results 1 to 25 of 43
Like Tree2Likes
    dakidd's Avatar
    Posts
    Global Posts
    69 Global Posts
    Default Full bars and horrible speed....speed test anyone
    Im posting this because I wanna know if im the only HTC evo lte user getting crappy speeds
    Sent from HTC Evo LTE
    Attached Thumbnails Attached Thumbnails Full bars and horrible speed....speed test anyone-uploadfromtaptalk1340457472015.jpg
  2. #2
    delta7's Avatar
    Posts
    Global Posts
    422 Global Posts
    Default
    If you not rooted, how do you take a screen shot?
  3. #3
    crxssi's Avatar
    Linux: The power beneath
    Posts
    Global Posts
    1,827 Global Posts
    Default Re: Full bars and horrible speed....speed test anyone
    Quote Originally Posted by dakidd View Post
    You are kidding, right? Hmm
    Number of bars is only weakly related to speed. In many areas, Sprint 3G can really, really suck and be very, very slow. If you consistently have speeds under 150Kb/s, even late at night, contact Sprint and have them "reprovision" you and update your data profile.
    Click "Thanks" and/or "Like" button on posts where someone helped you or you liked the posting. Provide HTC feedback here: http://www.htc.com/www/contact/email
  4. #4
    pteezay's Avatar
    Posts
    Global Posts
    285 Global Posts
    Default
    Quote Originally Posted by delta7 View Post
    Power button and home key
  5. #5
    Umm, LTE is not on yet - and Sprint's 3g Service has sucked up to this point - I'm not sure why you thought buying a new device would fix that. I'm afraid, my friend, that if you don't live in an area where network vision has started to address 3g service - it's going to be just as bad as it's always been. I live in Atlanta, and we've been through our 3g re-tool and it's given me results in the 1-2 mb/sec range - so join us all won't you - in the chant for "Sprint needs to just turn on LTE...whatever state it's in..?" (and yes, I'm aware and embrace the double entendre..
    Jack
  6. #6
    Default
    I'm getting 1.87down .89up
    Sent from my EVO using Android Central Forums
  7. #7
    Default
    While I'm not getting speeds this high constantly, I am consistently above 800kbps. Quite honestly I'm fine with those speeds until LTE works it's way here. Loads stuff much faster than I would expect when I'm tethered.
    Attached Thumbnails Attached Thumbnails Full bars and horrible speed....speed test anyone-uploadfromtaptalk1340464311663.jpg
  8. Thread Author  Thread Author    #8
    dakidd's Avatar
    Posts
    Global Posts
    69 Global Posts
    Default
    Ok I think I will call sprint cause this is all the time...never over a mb and again I use wifi but im having a horrible issue with that
    dakidd's Avatar
    Posts
    Global Posts
    69 Global Posts
    Default
    Here's a quick glimpse of my log of test
    Attached Thumbnails Attached Thumbnails Full bars and horrible speed....speed test anyone-uploadfromtaptalk1340466819209.jpg
  10. Thread Author  Thread Author    #10
    dakidd's Avatar
    Posts
    Global Posts
    69 Global Posts
    Default
    I guess im tired of the waiting....I had the og evo day one and 3d and now evo lte....I live in NY...long island to be exact and I've played the waiting game for so long...just frustrated...I've been with sprint for 14 years...so I think I've paid my dues
  11. #11
    crxssi's Avatar
    Posts
    Global Posts
    1,827 Global Posts
    You are probably wasting your time if you think getting under 1Mb/s is a problem on Sprint 3G. I have never had over 1 Mb/s for over a year and a half now. I am lucky to get 300Kb/s here. My advice was to contact Sprint if your speed is consistently under 150Kb/s (which it appears yours is) because your phone could be stuck in 2G mode (happened to me) and they CAN fix that.
  12. #12
    Do some tests in different areas, you might find the problem's limited to a specific spot rather than everywhere. I get bad speeds at my work, sometimes around 300 kbps at max, but often around 30 kbps. I thought my slow 3G speeds might be the phone or some electronic interference, or just Sprint's overall 3G service. But I found that just a mile away, I got speeds around 2000 kbps (it was actually faster than some crap free wifi I tried to use).
    So I found that Sprint has decent 3G in my area, just not consistent, and not where I need it most. Unfortunately, just knowing that doesn't really help that much. It doesn't seem like Sprint really does anything for dead zones, even in large metro areas.
  13. Thread Author  Thread Author    #13
    dakidd's Avatar
    Posts
    Global Posts
    69 Global Posts
    Default
    Ok it seems like there it's a tower issue by me...supposedly and I own my own business which isn't far from home less then 5 miles so I'm always connected to that tower so that's why speeds have sucked for about a month now..strange as when I was at the car dealership I got nice speeds which is closer to home them work but what ever....I'm gonna wait it out and see if things get better on the sprint side and if HTC is gonna fix the software issues....what else can I do
  14. #14
    Sprint is actively working on upgrading their entire network nationwide, some markets are being upgraded before others. It's called Network Vision and after Sprint is done they will have a nationwide LTE network, 1xRTT / 3G Advanced and HD Voice. They will also being incorporating Clearwire's TD-LTE network once the first sites go live in 2013 as well as VoLTE (Voice over LTE). In some markets that haven't been upgraded yet 3G is actually working just fine. It really depends on where you are located and it could be that Sprint is currently upgrading your market and that's why you are having issues.
    Over at S4GRU they have some sample LTE speed tests from a few that were able to connect to LTE in Athens, GA (I believe) and they are getting around 25-30mbps average and 30mbps+ peak. 3G speeds will also be much improved, on average they will run 1.6-2.5mbps.
    It is painful right now in some areas but soon enough it will all be fixed.
  15. #15
    Default
    I to live on long island south shore I just did a speed test in my house with no bars and hit in the 7 hundred
    from my HTC evo lte that was smuggled through customs in a kilo of cocaine
    Attached Thumbnails Attached Thumbnails Full bars and horrible speed....speed test anyone-uploadfromtaptalk1340484342383.jpg
  16. #16
    Default
    Quote Originally Posted by biggdogg9 View Post
    You should be happy with your speeds, this is what I get in my area and there are no signs of LTE in Sacramento, CA
    Full bars and horrible speed....speed test anyone-uploadfromtaptalk1340486509669.jpg
    Sent from EVO 4G LTE
  17. #17
    New EVO tethered to my laptop just after 2pm local time.
  18. #18
    MJBlanks's Avatar
    Posts
    Global Posts
    17 Global Posts
    ROM
    MeanRom ICS v2.0
    Default
    Mine is actually better than my OG EVO
    Attached Thumbnails Attached Thumbnails Full bars and horrible speed....speed test anyone-uploadfromtaptalk1340507804426.jpg
  19. #19
    Eric16's Avatar
    Posts
    Global Posts
    78 Global Posts
    Default
    Damn what internet service do u got? Our wifi speeds are about 10 mbps and that's the highest u can get
  20. Thread Author  Thread Author    #20
    dakidd's Avatar
    Posts
    Global Posts
    69 Global Posts
    Default
    Quote Originally Posted by Eric16 View Post
    We have optimum aka cablevision
  21. #21
    Default
    More complete most recent tests.
    Attached Thumbnails Attached Thumbnails Full bars and horrible speed....speed test anyone-uploadfromtaptalk1340520472146.jpg
  22. #22
    This is my best number so far. I typically get between 1 and 2 meg speeds though...
    This was on my way home from work early in the am
  23. #23
    Default
    All time best just now, spoke too soon in the last post.
    Attached Thumbnails Attached Thumbnails Full bars and horrible speed....speed test anyone-uploadfromtaptalk1340593643444.jpg
  24. Thread Author  Thread Author    #24
    dakidd's Avatar
    Posts
    Global Posts
    69 Global Posts
    Default
    Well since said tower issues are on deck for me I drove into the city to see if things were any better and from the looks of it...hell to the NO
    Attached Thumbnails Attached Thumbnails Full bars and horrible speed....speed test anyone-uploadfromtaptalk1340646413384.jpg
  25. #25
    ReyRey's Avatar
    Posts
    Global Posts
    33 Global Posts
    ROM
    Stock (Rooted) | CM9
    Around here the speeds are not so bad (as long as I stay around the area) other places not so good.
    Full bars and horrible speed....speed test anyone-2012-06-25-14.35.54.jpgFull bars and horrible speed....speed test anyone-2012-06-25-14.38.36.jpg
    Phone: HTC EVO 4G LTE
    Rom: Stock (Rooted)
    Kernel: Stock
    Recovery Image: TWRP
