- 07-08-2012, 12:25 PM
Thread Author #1
- 07-08-2012, 09:54 PM #2
- 07-08-2012, 10:28 PM #3
Re: Home screen takes too long to load
Is it possible to run too many in the background?
- 07-08-2012, 10:55 PM #4
- 07-08-2012, 11:29 PM #5
I was having problem with Sense reloading. I wipe and reinstalled my apps and it happened again. I was getting pissed. So I deleted unnecessary apps that were loading. Checked all my settings. I also made sure that animation was checked on. I haven't had a problem with Sense reloading ever since I made those changes. I love this phone. Its not perfect but its a excellent phone. HTC will fix the other issues soon.
- 07-09-2012, 12:22 AM #6
No problem here
Sent from my EVO LTE - 07-09-2012, 02:38 PM #7
- 07-09-2012, 03:26 PM
Thread Author #8
- 07-09-2012, 03:31 PM
Thread Author #9
- 07-09-2012, 05:24 PM #10
Ok. Sense keeps reloading. I total wiped the phone(apps, contacts, pcitures, everything). Started fresh with nothing. Reloaded all my apps except Vipre and Lookout Security. Don't know if those were interfering but I took them off. I made sure that under display and gestures animation was checked, developer options animation is checked and windows animation scale is .5x, transition animation is .5x. I did those changes and Sense doesn't reload. I can be in pictures and press the home button and it goes back fast. Any app and it goes back quick.
- 07-10-2012, 12:41 PM #11
Just a real quick search (its that thing at the very top of the page with the magnifying glass symbol) using terms "sense" and "homepage" turns up the following partial list of threads on the issue -- and this is just in the thread heading search, not the body of the posts:
Homescreen loading?
Slow to load homescreen
homescreen issue
Sense rebooting randomly
A fix coming for Sense rebooting bug?
I'm getting constant Sense reloads now...
Sense reboots and web browser
sense reloads after exiting chrome
Sense crashes repeatedly
Does Sense crash on EVO LTE?
Loading
A google search of the issue shows the following -- again this is not all the results a search gets, just some of them:
In general Sense has had reloading troubles across platforms for about a year or so depending on the device and the update where it seems to have started:
HTC's "community" forum had a number of threads about it which seem to have been deleted:
Specifically with the EVO LTE on other forums:
This is also a problem on the One X:
Pilot - Visor - Moto - Treo 300 - Treo 650 - Treo 755 - Pre - Evo - Evo 4g LTE - NOTE 2 - 10-10-2012, 07:58 PM #12
- 01-06-2013, 09:20 AM #13
I FINALLY GOT THE SOLUTION!!!
Go to "settings"»»"developer options"»»"don't keep activities"»»make sure this option is UN-CHECKED !!! The reason it's taking 5 seconds to go back to the home screen is because it needs to load the process for the home screen into memory from storage. Make sure this is turned off. This will decrease battery life.
I fixed my HTC One XL, hope this helps you too - 01-09-2013, 12:45 PM #14
- 03-11-2013, 05:37 PM #15
- 04-18-2013, 01:07 PM #16
I have an HTC Incredible with this white-screen loading problem.. I call it a warm boot, but it seems to happen after exiting sms messaging area, after using the camera and after closing some apps.
I cannot find the developer section and cannot activate it using the guide here.
I can see a developer page but tapping in there anywhere does not turn anything on. Am I missing something?
Reply
