Page 1 of 2 12 LastLast
Results 1 to 25 of 28
    Default LTE Lights Up in San Antonio
    Just a quickie to say that I just noticed the 4G icon on my EVO 4G LTE. I will put up a speed test result a bit later.
  2. #2
    Default Re: LTE Lights Up in San Antonio
    Getting intermitten 4G signal in Fort Worth...very low, comes and goes...can't get a speedtest on it...
    Well ... I can't get a speed test either. When I went back to do it, it had switched over to 3G again. They must be doing some last minute tweaking before the official launch. But at least it was a couple of exciting moments of LTE. lol
    Default
    LTE is up and down sporadically. But I was able to get a speed test. Not bad, but I think it should improve once there is more stability.
    Sent from my EVO 4G LTE using Android Central Forums
    Attached Thumbnails Attached Thumbnails LTE Lights Up in San Antonio-uploadfromtaptalk1342201927506.jpg
  5. #5
    i can get 4G to come up but only for a short period of time. the connection literally drops during the speed test and then i cant get it back.
  6. #6
    Only getting 3.5 up and 1.2 down in the Medical District in Fort Worth...
    Default
    Another speed test a bit later was a lot faster. This is in NE/Windcrest area.
    Attached Thumbnails Attached Thumbnails LTE Lights Up in San Antonio-uploadfromtaptalk1342204630339.jpg
  8. #8
    i cant wait till lte is in my area, they already have some lte towers ready but they dont actually have them broadcasting
    Default
    Quote Originally Posted by kiwicarlos741 View Post
    Hopefully the installations will move along more quickly as they gain experience from the launches.
  10. #10
    I got lte over at 1604 and Bandera. 6532kbps up 3906 up lasted enough for 3 speedtests and went back to 3g
  11. #11
    LTE speed test off HI 281 and Bitters measured 45 mbs down /46 mbs up.
    and 1mile away 281 and Nakoma....Nothing! I hope this doesn't turn into another 4g crap out! This is only day two so hopefully signal strength gets better.
  12. #12
    Just hit 35mps down/25 mps up off 281 and Nakoma.
  13. #13
    Epsom_D2's Avatar
    Posts
    Global Posts
    41 Global Posts
    Well in the NE just inside the 1604 Loop by Nacogdoches I get intermittent 4G. It will come on and then drop out or lose connection to 3G switch to 4G and then lose connection and revert back. The map says I should have coverage, but it doesn't appear to work correctly on my EVO. I tried a PRL and a profile update. Anyone having similar problems?
  14. #14
    mitsueks's Avatar
    Posts
    Global Posts
    95 Global Posts
    Ok I work at Stone Oak and 281 and we did a test here at work on 3 phone... EVO LTE Galaxy S3 and a Galaxy SII to show Wimax speeds.
    EVO LTE: 6523 kbps up/ 2536 kbps down
    Samsung SIII: 31526 kbps up/ 24563 kbps down
    Samsung SII: 11383kbps up/ 1507 kbpsdown
    The EVO would drop connection while doing the test... it took six times to get that good of a reading.
  15. #15
    Quote Originally Posted by Epsom_D2 View Post
    YEah, I'm using the Evo LTE and It only picks it up in certain spots, it's very defined. At work, I have it stationary and it is solid if I don't move the phone. I wanted the SG3 but situations worked out for the latter. This is second day of launch so they not have all towers active or maybe troubleshooting. I've been with sprint for 15+ yrs and every new launches have been a bit glitchy.
  16. #16
    Default
    Attached Thumbnails Attached Thumbnails LTE Lights Up in San Antonio-uploadfromtaptalk1342503036640.jpg
  17. #17
    Epsom_D2's Avatar
    Posts
    Global Posts
    41 Global Posts
    I was on Nacogdoches between Judson and O'Connor this evening and had a perfect 4g signal for about 1 hour and it was 10Mbps up/down. When I left dinner and drove home it reverted back to 3g.
    I did stop in a Sprint store today and they told me that by the end of the week they were expecting it to be 100% with switching between 3g and 4g problems to be corrected. Why Sprint would they **** of customers by saying the network is live without it being ready for prime time will be a question for the ages. Considering I have more than 18 years with Sprint as a carrier I'm not running away as they have always taken care of me and my business, but it would be nice if they were being honest with us on the 4g rollout.
  18. Thread Author  Thread Author    #18
    Default
    The startup process will be ongoing over the next few months. The process in SA will be ongoing until sometime in October. It started out at only 18% completion on the launch date.
    Network Vision / 4G LTE Deployment Running List as of July 16th
    Sent from my EVO 4G LTE using Tapatalk 2
  19. #19
    I started seeing the LTE icon last Friday when I was downtown. It was in and out, but I didn't think of doing a speedtest at the time. I did see a difference in speed when I had it, though. But on Monday at work, toward the end of the day, I noticed a 4G icon for maybe a minute. The speeds were pretty fast, but it quickly went back to 3G (and noticeably slowed down) and I haven't seen it since. :-(
    I'm wondering, why was I seeing the LTE icon on Friday and 4G on Monday? Isn't it basically the same service? Does it vary with where you are? I work in the NW part of town about 15-20 minutes from where I was downtown, so IDK.
  20. #20
    Mellimel22's Avatar
    Posts
    Global Posts
    2,164 Global Posts
    ROM
    Muzzyz 4.2.1 build
    Default
    Keep in mind u guys u have to update the prl too
    Sent from my Nexus S 4G using Tapatalk 2
  21. #21
  22. #22
    getting better and better by the day
  23. #23
    Epsom_D2's Avatar
    Posts
    Global Posts
    41 Global Posts
    Quote Originally Posted by mggm100 View Post
    Thanks for that one I didn't see that post. I just assume, as most consumers do, if you are going to say it is live, and post maps, it should be 100%. That being said, I can wait as it was plenty fast when I was able to test it.
  24. Thread Author  Thread Author    #24
    Default
    I remember the launch of Wimax being similar to this. When I got my OG EVO on launch day, Wimax was just launching in San Antonio. I had to go outside in order to get a very weak signal for the first few weeks. Then after a few weeks there was a dramatic improvement. I think the LTE startup will be about the same. At least I can get it inside the house this time. lol
  25. #25
    Epsom_D2's Avatar
    Posts
    Global Posts
    41 Global Posts
    mggm100, as I didn't live in anyplace that had LTE on launch day I didn't have the experience. Thanks for sharing.
    One thing I have realized is that when I am in an area with LTE the 4G indicator stays lit (does not go gray) with gray arrows unlike the 3G indicator which is gray with gray arrows. Does anyone know if this is normal behavior as I know when the 3G is lit up it means it is chewing through battery moving data and it appears that LTE is killing my battery (this could be because I keep turning the screen on to look)with the 4G/LTE lamp on, but no arrows flashing.
