kiwicarlos741
You don't know how network testing works. Any available signal was an incidental effect of sprint testing. The network was not active.
this proves that you don't understand the meanings of simple words that are taught to us in 2nd grade, if i can get on the LTE regardless of whatever your saying which doesn't have anything to do with the actual definition of what I've been saying, its active, I'm using the connection so its on. theres only on and off/ no maybe , active and inactive/ no maybe, nothing in-between, if i can use the LTE its active as its OPERATIONAL as i can get on and use it. OPERATIONAL = ACTIVE, I'm not talking about the network being up, I'm saying that the lte IS active and it is by the meaning of the word active, literally look above and read the sentences above in this post. you fail to see this and just make yourself look more and more unintelligent by the post
