Results 1 to 16 of 16
- 08-11-2012, 11:01 AM
Thread Author #1
Roam Control on Evo LTE
Since upgrading to the new Evo, my connection at work took a crap. I get no signal and even when I put the roaming to automatically the phone fights between sprint and roaming and it doesn't lock a signal.
I purchased roam control thinking the program would force the phone into roaming only. When i select the roaming option in roam control i see the indicator come up, but its not forcing the phone to roam. All the app is doing is telling me which signal I'm getting. If the phone decides to roam it tells me to what carrier it's. If its stay in sprints it tells me that. It's the app not working out is this what out was meant to do? I know Verizon customers have great signal in the building so the issue is not having a signal period. Thanks for the help. - 08-11-2012, 09:20 PM #2
- 08-12-2012, 02:01 AM #3
Roam Control was the first app I installed on my LTE. You need root.
Sent from my HTC EVO 4G LTE on a now non-LTE Network! - 08-12-2012, 10:48 AM #4
- 08-13-2012, 09:34 AM #5
Re: Roam Control on Evo LTE
you have to root for roam control to work. there are also some other options on XDA but you must be rooted also. I go in to roam everyday at work.
- 08-13-2012, 06:15 PM
Thread Author #6
- 08-17-2012, 12:17 PM #7
- 08-17-2012, 01:36 PM #8
- 08-17-2012, 01:56 PM #9
The phone will go with a weak sprint signal over a strong roaming signal which will prematurely destroy your battery and if its really weak it will basically switch back and forth all day which is even worse on the battery so why not just force the better roaming signal and be done with it?
- 08-17-2012, 02:05 PM #10
Sprint doesn't do unlimited roaming.
- 08-19-2012, 06:16 PM #11
They do allow unlimited data roaming but they get pissy when you go over 300MB a month and reserve their right to cancel the K.
Yeah well maybe strengthen your now network NOW.
Sent from my HTC EVO 4G LTE on a now non-LTE Network! - 08-19-2012, 06:19 PM #12
- 08-19-2012, 11:29 PM
Thread Author #13
- 08-20-2012, 08:58 PM #14
Simply everything is unlimited.....while on the Sprint Network. If you read the fine print, roaming data is unlimited up to 300 MB. If you continually go over that mark, you may get a nasty gram from Sprint threatening to cut off your service. It's happened to a couple of friends of mine. I've been close to 300 MB a few times and used to get nervous as much as I travel in rural areas not covered by Sprint. There's a lot of fine print in the service agreement, which you can read online, about roaming, including voice, which becomes an issue, if it's the majority of your usage. Simply Everything......kinda.
- 08-20-2012, 09:41 PM
Thread Author #15
- 08-20-2012, 10:20 PM #16
Thank you. Sprint told me a while back that they were changing their agreements regarding unlimited roaming, and they sent out courtesy calls to a lot of people. I know because I got one of them. They admitted that unlimited roaming was included but they were willing to let people off ETF free.
How about you learn basic grammar first. Maybe you should read the fine print in contract before you make yourself look even worse than you are right now.
Reply
