Results 1 to 7 of 7
    Default Call Duration Help
    So I've been searching for a way to determine call duration on the EVO 4G but with no luck. I have found 'Call History' but cannot figure out how to view the length of a phone call. Can anyone help me out?
    Thanks
  2. #2
    Default Re: Call Duration Help
    Wish i knew to been trying since day one
  3. #3
    ay
    ay is offline
    ay's Avatar
    Posts
    Global Posts
    749 Global Posts
    Quote Originally Posted by michaelkelly923 View Post
    Thanks
    I use CallTrack (..) to get call duration information. It may be more information than you need, but it does provide the information you are seeking.
  4. #4
    Default
    Sorry, I just checked and this no longer works in the stock dialer. I don't know why because it uses to. I've been using Rocket Dialer and it has this function.
    Thanks
    Long click on the call you want to know about.
    Sent from my EVO LTE using Tapatalk 2
  5. #5
    ay
    ay is offline
    ay's Avatar
    Posts
    Global Posts
    749 Global Posts
    Quote Originally Posted by Cyrene View Post
    Long clicking provides me with when a call took place, but not how long it was. You're able to view call duration by long clicking?
  6. #6
    Default
    Quote Originally Posted by aye View Post
    I just edited my post above right when you asked this. I double checked and it no longer provides call duration in the stock dialer. I've been using Rocket Dialer for a while now and I love it. I just disable the caller id in the app (cuz that doesn't work well) but it does provide call duration and has many customizable themes.
    Thanked by:
  7. #7
    I have a HTC Evo 4G LTE, I just installed: "Advanced Call History" -- (it's free), and seems to be working!
    see:
    ( play.google.com/store/apps/details?id=callHistory.logs )
    (it's its own app, you launch it -- as distinct from per-say integrating into the HTC-Sense GUI tools. It directly inspects the log files saved 'under the hood' to report history; meaning, unlike 'call timers' you can install it, and immediately see history of call duration on calls you've already made. )
