Results 1 to 3 of 3
- 09-13-2012, 01:26 PM
Thread Author #1
Help! Damaged Phone Storage
Need help/advice. I updated my phone with the newest Fresh Evo LTE 5.3.1 and the radio firmware. And after rebooting...noticed the Damaged Phone Storage notification. At first I thought it was no big deal cause it was the micro sd card. But then I found out it is the data/second partition on the internal phone storage. I tried to erase the phone storage...but that does not work. I am thinking of trying to restore back to stock and hoping the stock image restores the second partition.
Do you know what might of happened? And any options on trying to fix this problem?
Thanks. - 09-14-2012, 06:15 AM #2
Re: Help! Damaged Phone Storage
You probably just need to flash another recovery image on there, CWM or whatever you were using. When you installed the radio firmware it probably overwrote it. Are you sure you are still rooted?
- 09-14-2012, 12:19 PM
Thread Author #3
Need help moving apps from SD card to phone storage.
By deevel79 in forum Verizon HTC RezoundReplies: 8Last Post: 09-03-2012, 09:08 AM -
Will rooting my phone help my phone storage issue?
By PsychoUndead in forum General Help and How ToReplies: 14Last Post: 07-24-2012, 02:12 PM -
Ever ran out of internal phone storage? Byte Map Premium can help you
By stringernb in forum Android ApplicationsReplies: 0Last Post: 03-29-2011, 12:55 PM -
Phone storage problem. plz help!!!
By henrykim in forum Verizon FascinateReplies: 6Last Post: 02-27-2011, 06:19 AM -
Help with internal phone storage
By WalterSobchak in forum Incredible Rooting, ROMs, and HacksReplies: 8Last Post: 09-21-2010, 03:45 PM
Reply
