Results 1 to 3 of 3
    Default 3G Speed Diminishes
    It seems that over time, my EVO will seem to lose 3g speeds. It goes from getting about 150 kbps to around dial up speeds. Restarting the phone returns the phone back to the original speeds, but this needs to be done everyday. Os there any way I can exchange this phone for a different model if the problem persists because I don't even want to deal with the refurbished models if I exchange this.
    Sent from my EVO using Android Central Forums
  2. #2
    Default Re: 3G Speed Diminishes
    Download "3g reconnect" and see if that helps. Basically all it does it scan for a new tower if the signal gets too low (threshold set by you or the system). And on that note...if it's Sprints towers combined with the area you're in you may be out of luck.
  3. #3
    Also the icons that represent 3G and 4G arent set correctly. If your device is stuck on 1x it is still represented as 3G. When in fact your not on 3G, yout on 1xrtt data service..
    I used a widget called Signal Monitor. It would show 1x and my data speeds were abysmal.
    DropBox lets you sync files across Android, iOS, and Desktop Computers. Sign up for free, install, get me and you extra space! DropBox
    Twitter @AndroidTechGuy
    Google+Google+
  1. Post your 4G/3G speed!
    By Beezzy in forum Sprint
    Last Post: 07-01-2010, 03:25 AM
  2. Post your 4G/3G speed!
    By BazzBro in forum HTC EVO 4G
    Last Post: 06-28-2010, 10:18 AM
  3. 3g speeds down in certain areas
    By jrobinson in forum Sprint
    Last Post: 06-27-2010, 03:26 PM
  4. Droid w/Froyo Verizon 3g Speed Tests
    By b1gt78 in forum Motorola Droid
    Last Post: 06-21-2010, 02:48 AM
  5. 3g Speed drop
    By mikea3000 in forum Google / HTC Nexus One
    Last Post: 06-06-2010, 01:26 PM
