Results 1 to 8 of 8
- 11-09-2012, 09:36 PM
Thread Author #1
How to get amazing battery life
Before I begin, let me say that for a while, my EVO seemed to have less than desirable battery life. I found that the cause of this was that while I was in school, my phone would only receive a signal about 10% of the time. I found that switching off my navigation and auto-sync during times where I was in a dead zone dramatically increased my battery life. I know this seems obvious, but its the best way to increase battery life. Btw, today I got 4 hours of screen-on time and I still have room left to go.
Sent from my EVO using Android Central Forums - 11-10-2012, 05:18 PM #2
Re: How to get amazing battery life
I have auto sync off always. I have not ever run into an issue where I need it on. I don't push my emails. I treat email like real mail,, if I want to know if I have mail I go and check. Any app that has push notifications I leave them off. Just like mail, if I want to see what someone said on Facebook I go check. I take the same approach with all apps. I think I would smash this thing if it was beeping every 5 mins. I get at least 12 hours of steady use.
EVO-LUTION 4G LTElove my evo. - 11-10-2012, 08:46 PM
Thread Author #3
- 11-10-2012, 08:54 PM #4
- 11-20-2012, 12:03 PM #5
just got this phone. loving it so far.
question re battery life - battery is dropping like 5-10% per hour. from what i have been reading about the battery life, i would think it should be much less. i usually keep wi-fi and bluetooth on all the time. gps is off. have 3 gmails accounts, 2 yahoos, but those are only updating every 4 hours. during the day, i am mostly using it for some texting, a few calls, but nothing very heavy. wondering if the battery is going faster than it should be.
if more info is needed for a better answer i'd be happy to provide.
thx. - 11-20-2012, 01:45 PM #6
You should go through your apps and check for ones that active check for notifications. The biggest culprits are social network, weather, and some games. They usually default to checking every five minutes which can impact your battery pretty heavily if you don't have a strong data connection. Most apps turn on these active notifications when you install them.
- 11-20-2012, 08:59 PM #7
One app: Easy Battery Saver. This thing extends your battery to double or triple life depending on the settings you choose. Initially the phone would last me 6 - 8hrs, but once i got Easy Battery, i always had 40 - 60% battery remaining at night on 16 hour days. it gets annoying sometimes but it's done it's job the best.
- 11-20-2012, 10:12 PM #8
Click "Thanks" and/or "Like" button on posts where someone helped you or you liked the posting. Provide HTC feedback here: http://www.htc.com/www/contact/email
Rooted and ROM'd - how to get maximum battery life?
By LDubs in forum Bionic Rooting, ROMs, and HacksReplies: 3Last Post: 11-10-2011, 09:50 PM -
how to get great battery life?
By m.vasquez009 in forum Sprint Galaxy S II Epic 4G TouchReplies: 26Last Post: 10-07-2011, 04:03 PM -
[How To] [Discussion] Improve Battery Life
By gunnermike53 in forum Verizon Fascinate Rooting, ROMs, and HacksReplies: 194Last Post: 07-18-2011, 05:07 PM -
[How-To] Troubleshoot bad battery life
By Nick7 in forum LG Optimus S Rooting, ROMs, and HacksReplies: 1Last Post: 01-28-2011, 07:37 AM -
best way to get good battery life
By pedromartinez1983 in forum HTC EVO 4GReplies: 7Last Post: 06-07-2010, 11:09 PM
Reply
.jpg)
